IMPORTANT!! U-Joint Issue---SOLVED - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2010, 12:25 PM   #1 (permalink)
View DJ_SOLO's Photo Gallery
Thumbs up IMPORTANT!! U-Joint Issue---SOLVED
Okay, so for a couple of weeks I have been experiencing very hard steering. It felt like my power steering let go. Checked everything and it was fine. I thought then maybe rack or/and pinion...checked it..still it was fine. Checked mostly all other aspects of the suspension and steering...seemed fine.
Well after much frustration I went to see my mechanic. He said simply go down to the hardware store and pick up a can of WD40 of similar type product and apply it to the U-Joint that is located right where the steerign colum comes through the firewall to the engine bay.
This morning bright and early I ran down to the local Home Hardware and got myself some WD40. I went home sprayed it on and let it sit for about 20 mins or so. I then started it up and took it around the block. WOW! the steering was even better then when i first got the car!
So there you go if your steering get hard or starts to stick, simply apply some WD40 to the U-joint right where the steering colum comes through the firewall into the engine bay, then let it sit for 20 mins or so and take it for a spin. Should be fine, if not consult a local mechanic but it worked great for me!
DJ_SOLO is offline   Reply With Quote
Old 04-15-2010, 04:01 PM   #2 (permalink)
tacosteelersman's Avatar
Gameroom cash: $170177
View tacosteelersman's Photo Gallery
Good to hear you got it fixed, THANKS for posting the solution..
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
tacosteelersman is offline   Reply With Quote
Old 04-16-2010, 01:29 PM   #3 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Exclamation Don't Stop there; Safety Hazard!
My 2Cents, you need to follow with that action and A) best choice, replace the joint or at a bare min. B) add some real oil to keep it alive.
WD - loosened it and got it free but WILL NOT LAST!
Grab some Mobile1 synthetic (example) and start dropping that on there. Rotate, drop some more. Do this every couple of days from a different positions.
It will bind again as WD is not a lasting product. I know it got it moving for moment, but don't kid yourself, its only temporary and the last thing you or anyone else wants is the steering to lock and cause a crash.
Get some real lube in there!
73sport is offline   Reply With Quote
Old 04-16-2010, 03:35 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
^ x2
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-16-2010, 03:43 PM   #5 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
i use astroglide
rusty9 is offline   Reply With Quote
Old 04-16-2010, 04:54 PM   #6 (permalink)
Gameroom cash: $303255
I agree with what has been said about eventually replacing that joint. The WD-40 will wash away pretty quickly when it rains. If you are not going to replace it right now, I would at least spray some white lithium grease on it. That will be a lot more water resistant then WD-40.
Mike
Mike Gerber is online now   Reply With Quote
Old 04-16-2010, 05:08 PM   #7 (permalink)
V8'sRGone
73sport's Avatar
Originally Posted by rusty9 View Post
i use astroglide
Thanks rusty; i needed a laugh today! rofl
?maybe you can PM him some. . .
Old 04-16-2010, 05:10 PM   #8 (permalink)
V8'sRGone
73sport's Avatar
I don't think rain or sun is the question as it'll be gone before sunset regardless. . . .
WD
