Gen 4 Owners: Rim/Tire question. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2010, 05:33 PM   #1 (permalink)
Rabid Teddy
Ace2424's Avatar
View Ace2424's Photo Gallery
4th Generation Gen 4 Owners: Rim/Tire question.
215/60/16 on Drag DR-16's x7"w. Yes or No?
Question is:
Will it rub @ 215 or should I go 205?
Super White 1994 Celica GT 5SFE 5-Speed - 150,000 Miles - Still Driving
Vintage Red Pearl 1999 Camry 5SFE - 216k Miles - Totaled R.I.P.
Ace2424 is offline   Reply With Quote
Old 04-16-2010, 05:40 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
97-01 gen4 camry were also made with factory stock 205/60/16 setup, mounted on 99-01 Camry Solara gen1 (same chassis), so i think you are fine with 205 kinda safely... though i got no idea about offset and stuff ...
Old 04-16-2010, 05:41 PM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
215 is going to make the tire look pregnant on a 7" wide wheel. Play with this. http://www.rimsntires.com/rt_specs.jsp
edit: typical camry offset is about +38, IIRC.
'07 Honda Ruckus Big Bore
Old 04-16-2010, 06:49 PM   #4 (permalink)
Rabid Teddy
Ace2424's Avatar
Tiredirect.com has a good price on what I'm looking for. Thanks guys
Old 04-17-2010, 12:00 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
no...it wont. I had 225s on 16x7" wheels and a 55 side wall and theres barely any bloat. you have to understand that any tire with a 50+ side wall will have some bloat because thats more sidewall to flex. 215 is the PERFECT size for any 7" wheel.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-17-2010, 01:25 PM   #6 (permalink)
Freakin Scooters
^ Trust bird on his one.
The Following User Says Thank You to LynchburgCSI For This Useful Post:
White95Cam (04-17-2010)
Old 04-18-2010, 02:54 AM   #7 (permalink)
Rabid Teddy
Ace2424's Avatar
Ok! Sounds good
Old 04-18-2010, 03:03 AM   #8 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
^ If going with tiredirect, you get 8% Bing cashback too
2007 Camry 2.4L 5M
Old 04-18-2010, 08:32 AM   #9 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
GEN 4 I4s came with 195/70R14's stock (that's 1997-1999)
GEN4.5 I4 came with 205/65R15s stock (except for 2000 CE, which still came with 195/70R14)
If you want to keep the overall tire diameter about the same with a gen4 I4, a 16" size that will work well is 205/55R16s
If you want to keep the overall tire diameter about the same with a gen4.5 (except 2000 CE), a 16" size you want is 205/60R16 or 215/55R16.
I have 205/60R16s on my 2000 Camry LE on 16X7 Fondmetal Wheels with 42mm offset. There is sufficient inside clearance to install 215s without rubbing the struts, but with this offset, it's the outside you want to think about.
Note: 2000-2001 Camry XLE V6 and 1999-2001 Solara V6 SLE models came with 205/60R16 tires stock, but was mounted on a narrower rim (16X6)
You can see on the photo below the front tire/wheels come all the way out, the sidewall sits pretty much flush with the edge of the fenderflare. It looks good the way it is, but if I install 215s, it will stick out just a tiny bit.
That's my right front wheel.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 04-19-2010, 10:54 AM   #10 (permalink)
Quattrovalvole's Avatar
View Quattrovalvole's Photo Gallery
Check these 2 links perhaps they will help:
http://www.toyotanation.com/forum/t52045.html
and the tire size calculator http://www.miata.net/garage/tirecalc.html
_______________________________________________
1997 Camry LE V6
16' Enkei's
Pura vida from Costa Rica
Quattrovalvole is offline   Reply With Quote
Old 04-19-2010, 02:49 PM   #11 (permalink)
Rabid Teddy
Ace2424's Avatar
Can you take a side pic for me? Trying to figure out if I should do the 55 or 60 height with my eibach pro springs
