Air Intake Confusion??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2010, 04:44 PM   #1 (permalink)
View PhuTech07's Photo Gallery
So I bought a weapon r dragon air intake, and installed it everything fine,
here is the but,.....
I don't/can't locate the so called "PCV Hose" to connect from the intake to wherever its suppose to go.
One end goes into the intake pipe on the side, where I taped it up incase anything got in there.
I don't know where the other end connects to.
Can anyone please give advice
Thank You
-Camry Le 1993 4dr sedan
PhuTech07 is offline   Reply With Quote
Old 04-17-2010, 05:19 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
You don't need that for this car. Just keep the hole plugged.
Just for your info, your PCV valve is on your valve cover right by your throttle body. The PCV hose connects the PCV valve to your intake manifold. On some cars the hose runs to the intake pipe instead of the manifold, and that is when you would need that hose connected to your intake pipe.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 04-17-2010, 05:22 PM   #3 (permalink)
Ahhhh I see, Thank you for the speedy reply =)
Old 04-18-2010, 02:03 PM   #4 (permalink)
View P3VZ's Photo Gallery
i also have a question about intakes. alot of ppl r saying that there are no intakes aftermarket for the 3vz-fe but i have found a few. I was wondering if these would fit
http://www.andysautosport.com/toyota...p00029020.html
http://www.andysautosport.com/toyota...p00029030.html
I dont undertand how they would fit b.c it looks like the 3vz-fe has this AMF????!! or that huge thing in the intake which most cars dont have...?
http://img.photobucket.com/albums/v4...wers/AFM-1.jpg
P3VZ is offline   Reply With Quote
