Not hitting redline? - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: What type of engine do u have in your car?
Turbo Charged 1 3.57%
Super Charged 1 3.57%
Naturally Aspirated 26 92.86%
Multiple Choice Poll. Voters: 28. You may not vote on this poll
Old 04-17-2010, 11:54 PM   #1 (permalink)
The-Camry-Guy's Avatar
View The-Camry-Guy's Photo Gallery
I have a 1994 Camry v6 (vienta) auto. When i floor it it does not hit the redline (at about 6500rpm). In fact it changes at about 5700rpm or so. Is this normal?
Cheers
(Poll is totally random)
The-Camry-Guy is offline   Reply With Quote
Old 04-17-2010, 11:55 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
mine starts limiting revs at above 6,350 or so. 2000 4 cylinder 2.2L (5s-fe california specs)
Old 04-17-2010, 11:58 PM   #3 (permalink)
thanks for your post.
Where abouts is ur redline? Is it also about 6500rpm? thats weird that urs limit is higher than mine. and the 5s-fe is the 4 cyl version of my model as well (im pretty sure). do the 4's run higher than the 6's?
im mainly concerned as to whether this is normal or there is something wrong.
thanks
Old 04-18-2010, 12:05 AM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
seems like 6,250 or so starts the red line, so that pretty much around number the rev limiter starts kicking in.
this is not my car's picture. i took it from a thread about missing O/D off indicator light on dash of gen4 camry 4 cylinder (someone posted a DIY how it looks and so on).
Old 04-18-2010, 12:14 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
if i use ECT the car shifts at about 100rpms before redline. with the exception of 3-OD shift which will usually shift at about 6100.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-18-2010, 12:19 AM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
my car is automatic.
hmm, i don't have ECT button, only "o/d off" on shifter which i think was depressed (o/d inactive).
Old 04-18-2010, 12:39 AM   #7 (permalink)
so urs changes at redline, here is a pic of mine:
as u can see my redline is 6500 but it limits it before 6000, at around 5600 or so i think.
when i shift ECT is off. shouldnt it still shift closer to redline?
r u sure, my ECT is near the gear lever.
Old 04-18-2010, 01:42 AM   #8 (permalink)
Gameroom cash: $325545
View adalex's Photo Gallery
4th Generation
And here I was thinking that it was cool that somebody had almost the exact same miles as me :P lol
thats my instrument panel and I'm the one who posted about the missing O/D issue LOL
adalex is offline   Reply With Quote
Old 04-18-2010, 03:54 AM   #9 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
if it's auto, it'll only hit redline if u put it in L or 2 i think..have ECT on and OD off helps accelerate, but i wouldn't drive with them on all the time.
my 5 speed manual hits redline all the time =D
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is online now   Reply With Quote
Old 04-18-2010, 07:31 AM   #10 (permalink)
k, isnt OD just allowing it to shift into 4th gear? so that shouldnt have an effect on the limiter? but ECT may, cause instead of hydralically controlled shifts it is controlled electronically? is that right?
lol what a coincidence.
Old 04-18-2010, 09:05 AM   #11 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
The 3VZ should be able to hit 6400/6500 sinply by flooring it.
Often the tach's are not 100% accurate. It may be possible your's is reading a little lower then the RPM's really are.
5 Lug Corolla WHAT?
Old 04-18-2010, 09:44 AM   #12 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
View Bankos66's Photo Gallery
That is my 94 Camry V6 XLE
1994 Camry V6 XLE -- Totalled
1995 Lexus ES300
Bankos66 is offline   Reply With Quote
Old 04-18-2010, 09:45 AM   #13 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Originally Posted by The-Camry-Guy View Post
when i shift ECT is off. shouldnt it still shift closer to redline?.
ECT is there to hold revs, it only does it right in the first two gears(unless boosted). if i have ECT off, the car will shift sooner at WOT.
R.I.P.
Car Domain:
Old 04-18-2010, 09:58 AM   #14 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
OD is like a 5th gear pretty much. It's just an extra drive, or over drive.
If you turn it off, you stay in the first four gears longer, therefore would get closer to redline.
....I think. I'm a manual guy myself haha.
Chris Crash is offline   Reply With Quote
Old 04-18-2010, 10:19 AM   #15 (permalink)
Our car's have 3 gears and OD.
OD has NOTHING to do with redline.
'96 5SFE
'96 1MZ-FE
5 Lug Corolla WHAT?
