What's wrong in these pictures? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2010, 12:18 AM   #1 (permalink)
View Rattlin_Steele's Photo Gallery
I'm doing a 5FSE motor swap thanks to a failed attempt by a mechanic to repair two bad rod bearings. These are pics from the broke motor that had been pulled from the car for the repair. It's now pulled in prep for my swap and here's few things I noticed.
I don't mean to slam all mechanics by any means, but a few sure give the profession a bad rep.
Rattlin_Steele is offline   Reply With Quote
Old 04-19-2010, 12:24 AM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Holy Crap!!! That engine's been mangled!!!
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 04-19-2010, 12:55 AM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Urk. Looks like something slipped a mite when raising / lowering the engine.
Old 04-19-2010, 08:40 AM   #4 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
where in florida are you? we just finished doing a swap on 2 4cyl camrys. could have squeezed your car in
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 04-19-2010, 09:39 AM   #5 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
If you need that sensor and bracket in the bottom picture, I've got that too!
Chris Crash is offline   Reply With Quote
Old 04-19-2010, 09:56 AM   #6 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Pictures equal =>> I got it out Boss! Likely with a Forklift and Chain!
I'm so glad my engines aren't all rusty and nasty looking like those. No offense Rattle. . .
So the one with the mounting boss (threads yanked from the block), theres something above it to the right looks like it plastic with rust in the middle. What is dat?
73sport is offline   Reply With Quote
Old 04-19-2010, 05:21 PM   #7 (permalink)
Looking closer it appears to just be a flat spot on the block with (most of) the paint still intact. They're somewhat recessed so the mount bracket doesnt make contact there.
Here's pics of that area on both 5SFE motors, broke one and replacement. Interesting to note the differences in casting/holes. The green arrows point to where the bracket bolts go. Note the hole on the lower left DID NOT have a bolt in it! Also visible in the upper left is the block coolant drain valve. First motor I've had that had this (that I know of). Pretty handy.
Old 04-19-2010, 05:23 PM   #8 (permalink)
That would've been sweet! However, I'm at almost the complete other end of the state from you. Panhandle, Destin area.
Old 04-19-2010, 05:25 PM   #9 (permalink)
Chris, I think I'm good on that. The bracket's fine and I took the MAP sensor off the donor car. But just in case, what year is your MAP sensor off of?
Old 04-19-2010, 05:29 PM   #10 (permalink)
1997.
Should fit your 99 (If that's what you have.)
Old 04-19-2010, 11:08 PM   #11 (permalink)
V8'sRGone
73sport's Avatar
Looks like the un-rusted version has the "fit all" bosses drills and tapped for witness relocation into other chassis. . .
Whats the difference in years between the two?
Old 04-19-2010, 11:18 PM   #12 (permalink)
I don't think there would be a difference, to be honest.
Old 04-19-2010, 11:29 PM   #13 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Originally Posted by Rattlin_Steele View Post
Looking closer it appears to just be a flat spot on the block with (most of) the paint still intact. They're somewhat recessed so the mount bracket doesnt make contact there...
Yes and there are differences among 5sfe's are far as their casting goes. In perspective on someone doing a 5SGTE set up, the collant gallies on the block vary, some similar to the 3SGTE while others aren't. Also, +1998 5SFE blocks are casted with thicker cylinder walls, which is for boostin
RichieRichJP is offline   Reply With Quote
Old 04-19-2010, 11:54 PM   #14 (permalink)
Turns out the broke rusty one is a 2001 according to its VIN. The other is a 1999. This will be the third motor for this car (1997).
