need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2010, 12:57 PM   #1 (permalink)
View CamRyer's Photo Gallery
need help
hey guys need help with my 95 camry manual....
starts up and idle but when driving it as a lag and you floor the gas paddle it as a super lag and the car will just die. i did change the spark plug and the spark plug wire but still the same. don't know wat is causing to do it...
cool
CamRyer is offline   Reply With Quote
Old 04-19-2010, 02:14 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Are you set up to measure fuel pressure? First thing I'd suspect is fuel pressure (fuel pump or fuel filter)...an engine dying that fast usually isn't a single injector. If you aren't set up for fuel pressure measurement, you could just take it out on the open road and see how well she maintains high speed...usually a restricted fuel path won't allow a whole lot at top end.
I'm not a big fan of shotgunning parts, but if the fuel filter is pretty old, you could just try changing that out.
