Oil Leak and Burning Smell - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2010, 03:29 PM   #1 (permalink)
camry.toyota1998's Avatar
View camry.toyota1998's Photo Gallery
4th Generation Oil Leak and Burning Smell
Hello all,
I am new to this forum, I have 1998 Toyota Camry LE V6 -3.0L and recently i noticed that oil leaks around the engine and its leaking to exhaust and causing burning smell, I took it a mechanic and he advised me to replace this parts.
Replace:
1. R&R Spark Plug Tube Seals
2. Valve Cover Gasket (Left & Right)
I am planning to replace it, is there anything else i can ask them to check and replace while they work on Valve Cover Gasket.
From the discussions in this forums, I saw that i can make them check Spark Plug (Tune Up), Please advise.
They are charging me around $320, is it fair amount, Please let me know.
I appreciate your response.
Thanks!
camry.toyota1998 is offline   Reply With Quote
Old 04-19-2010, 04:38 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
$320 parts/labor seems fair to meBe a LOT more at a dealer. While at it, I'd have the spark plugs and PCV Valve/grommet changed. It shouldn't cost much more.
5 Lug Corolla WHAT?
Old 04-20-2010, 12:20 PM   #3 (permalink)
4th Generation
Thanks for your reply!
Old 04-20-2010, 03:23 PM   #4 (permalink)
Not a problem. After the valve covers are replaced, you MAY still have some burning for a week or so as the back of the engine will still be covered in oil. So do not be alarmed if that happened.
5 Lug Corolla WHAT?
Old 04-20-2010, 06:18 PM   #5 (permalink)
5S-FE
1998CamryLE's Avatar
View 1998CamryLE's Photo Gallery
I had the same problem on my 98... the cover gasket fixed it.
1998CamryLE is offline   Reply With Quote
Old 04-22-2010, 02:20 PM   #6 (permalink)
Do i need to replace intake plenum gasket as well, while replacing Valve Cover Gasket.
Old 04-22-2010, 02:21 PM   #7 (permalink)
If you don't mind, May i know how much did you spend on replacing Valve Cover Gasket.
Old 04-22-2010, 02:37 PM   #8 (permalink)
Official TN member
SoulTaker's Avatar
Gameroom cash: $118801
View SoulTaker's Photo Gallery
3rd Generation
After the valve cover gaskets on my 3VZ were replaced, I saw some engine oil aroung the engine oil cap and around the valve cover. And also the engine vibrates but it wasn't vibrationg before the valve cover gaskets were changed.
SoulTaker is offline   Reply With Quote
Old 04-22-2010, 11:05 PM   #9 (permalink)
View caveman017's Photo Gallery
I replaced the gasket in about 25 minutes on my camry. I think it cost around $20?
1997 Camry LE, i-4, auto, KYB GR-2 and mounts in the front
caveman017 is offline   Reply With Quote
Old 04-23-2010, 06:59 AM   #10 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
Caveman017, looks like you have the 5S-FE engine, so to replace a valve cover gasket, you pull one valve cover off.
These guys are talking about a V6. At a minimum, they have 2 valve covers to deal with. And I'm pretty sure the valve cover on the firewall side requires the removal of the entire intake manifold assembly. Quite a bit more work involved on the V6.
93celicaconv is offline   Reply With Quote
