RTV Reccomendations for the exterior of my car? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2010, 01:30 PM   #1 (permalink)
95 5S-FE
CROYCE992's Avatar
View CROYCE992's Photo Gallery
Hi all,
I bought a rear window visor last year and the first one I put on dropped in about a week from my rear window. The 3M double sided tape must have had imperfections which allowed water to flow through and eventually fail. The seller shipped me another one for a few dollars and this one I installed and lined the entire top edge of it with black electric tape to not have the same incident happen again - temporary fix.
Now that the weather is warmer I want to use an RTV to seal the top of the rear window visor so that I can take off the electric tape and not worry about it falling again. ANY reccomendations? I am looking for something relatively cheap that will hold up for years against rain, snow, salt, and snow.
4T 6M1 1995 Toyota Camry 5S-FE DX AT Sedan - 171k miles
CROYCE992 is offline   Reply With Quote
Old 04-20-2010, 05:12 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
9/10 times it's not the RTV/tape you use, it's HOW you apply it. Make sure you have a clean surface, make sure you use lots of pressure and hold it on there while it adheres for like 60 seconds. As far as RTV goes, IMO, I WOULDN'T use it. Just get some good 3M tape and try it again.
'07 Honda Ruckus Big Bore
Old 04-20-2010, 08:20 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Maybe this will work?
http://www.permatex.com/products/Aut...rip_Cement.htm
Check also other products in the excellent Permatex lineup:
http://www.permatex.com/products/Aut...erior_trim.htm
Originally Posted by CROYCE992 View Post
Hi all,
Old 04-20-2010, 08:54 PM   #4 (permalink)
95 5S-FE
CROYCE992's Avatar
I knew I forgot to mention something: I did thoroughly clean the area before hand. I used Windex and cleaned my rear window using a microfiber cloth till it was literally "squeaky" clean not once but twice covering a wide area both times. The first time however, I just kind of stuck it on there and pressed down a few times. The second time I carefully bended the piece against its normal curvature and applied it carefully from one side to the other so that not only would the adhesive stick but a little bit of extra pressure would be applied by its own curvature which I believed to be the best possible way of installing it. Now to be careful I did this (NOTE: this is the second brand new one which is held on by its own curvature and factory fresh 3M tape but I added tape on top to prevent any water to deteriorate the adhesive):
Basically, I want to remove the tape which did its job during the winter and line the edge of the visor with a recommended RTV to seal the 3M adhesive strip from the majority of elements it would face from the top side at least - I am not planning on lining the underneath.
This way my friends will stop asking me if its being held on by tape and I will once again be able to see the chrome trim surround my rear window = way better looking.
Old 04-24-2010, 03:44 AM   #5 (permalink)
95 5S-FE
CROYCE992's Avatar
any other recommendations? maybe something i can find on eBay for cheap or possible even Amazon?
Old 04-24-2010, 07:30 AM   #6 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
I agree with Ken
Windex is not the best pre-cleaner for 3m tape...I've always use Alcohol to clean the surface before the application. Never had a problem with it (3m tape)coming loose.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
