Squeaking sound when not hitting gas?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2010, 02:11 PM   #1 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
View Bankos66's Photo Gallery
3rd Generation Squeaking sound when not hitting gas??
Could it be my shocks? Brake pad falling off? Axle? Bearings? im clueless
1994 Camry V6 XLE -- Totalled
1995 Lexus ES300
Bankos66 is offline   Reply With Quote
Old 04-20-2010, 10:29 PM   #2 (permalink)
View Camry LE 94's Photo Gallery
More info would be helpful... Where does the squeaking come from and when does it happen? We can't help you if you don't help us understand what the exact problem is...
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 04-21-2010, 05:18 AM   #3 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
I have no idea. Thats the thing. It might be coming from the front left wheel well but not positive. When I hit the brakes, the sound goes away
1995 Lexus ES300
Old 04-21-2010, 07:46 AM   #4 (permalink)
So it happens when you are on the highway? Just cruising around town? Both? Is is a constant squeak or does it go on and off? Is it always there when you don't hit the brakes? If it goes away when you hit the brakes, then I'd think it has something to do with your brakes... When's the last time they've been changed?
Old 04-21-2010, 08:30 AM   #5 (permalink)
View flyeri's Photo Gallery
Here is a guess. The disk brakes pads have a wear sensor on them. When they get down to set point a small metal tab begins to touch the brake rotor when the brake pedal is not depressed. When you press the brake pedal the sound stops. Get your brakes checked before they wear to the point that that they are dangerous or you begin to do damage and have to replace rotors.
flyeri is offline   Reply With Quote
Old 04-21-2010, 09:51 AM   #6 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
I just got brand new rotors about 4,000 miles ago. I am going to jack up the car tonight and replace all the pads and hopefully that does the trick.
1995 Lexus ES300
Old 04-21-2010, 11:24 AM   #7 (permalink)
Gameroom cash: $303255
The noise could be form the brake pads vibrating in the calipers. That's one thing that happens a lot and will go away when you apply the brakes, as the pads are then pressed against the rotors. When you replace the pads be sure to use the 2 shims provided by Toyota on the back of the pads. If the shims are not there or they are aftermarket pads, then use some disc brake quiet on the backs of the new pads. It's a tacky substance that's either sprayed on the backs or applied as a gel to the backs. That usually elimintes any brake pad vibration.
Mike
Mike Gerber is online now   Reply With Quote
