If you're going to be charged $120 for loosening the tensioner bolt through the timing cover port, turn the crank 2 revolutions, and tighten again, then $120 is a ripoff.
You do need some special tools like pulley holder, torque wrenches, breaker bar, jack/stands, etc to attempt this. And a mechanically inclined friend should be required if you haven't done this type of things before.
If you can follow instructions to the letter, then I don't think it's that difficult. What tools do you have? Check the timing belt in the DIY section too.
Do a "complete" timing job, using at least:
(older
www.rockauto.com prices for 3/5SFE)
GATES TCK199 (kit of timing belt with two pulleys and instruction)
$84.79
GATES Part # K030295 PS belt $4.32
GATES Part # K050435 Alt/AC $12.12
FEL-PRO TCS45641 Cam seal $4.11
FEL-PRO TCS45920 Crank seal $6.04
BCA Part # 221820 Oil pump seal $2.71
AISIN (Toyota #16110-79185) water pump $58.79
FEL-PRO VS50304R valve cover gasket set $13.94
Use Toyota OEM parts if you like.
Originally Posted by toywhiz
This is for my 1999 Camry LE – 4 cylinder car. It has approx 92K miles on it.
From the past 6 months or so I have been noticing a louder than usual idling sound – sounds more like high RPM when I start the car in the morning. I recently took it to a mechanic and he said that I needed to get a new timing belt or have the existing one “adjusted”. Cost for replacing it was $250 and the cost for adjusting was $120. I believe the belt itself does not cost more than $20 which means I am paying $230 for an hours worth of work. So now I am thinking about doing this myself and had a couple of questions for you guys:
1. Adjust v/s replace belt – which one is better? If I were to do a replace then wouldn’t that also involve some adjustment anyways?
2. Does one need any special tools to do this job? My biggest DIY so far has been fixing (not replacing) a worn out starter on the same car. With my current level of expertise, is the timing belt project something than I can do by myself?
Thanks in advance!
