Thanks csaxon. I will check it out later. But if there a short there, would it blow a fuse already?
I read some other posts about this code and some members had trouble with their back lights not working.
All of my rear lights are working fine now.
Originally Posted by csaxon
P1780 is usually apinched or broken wire going from the neutral safety switch to the rear tail lights/back up lights. Check the wiring harness in the trunk where it flexes. I bet you'll find at least 1 damaged wire. Its usually the ground wire.
