Does it have a wire attached to it at all?
Honestly I have done no research on this nor have I seen it. If it has a wire sometimes they use pressure differential valve to detect master cylinder failure.
That is, if the M/C is actuated (depressed), both of the systems (front and rear) should build pressure. If one does and one doesn't then the valve (piston) is moved off center tripping a switch indicating a hardware failure (because the piston no longer has near equal pressure on both sides, the valve moves triping the indicator).
Because yours does not connect to the front lines, it seems its only acting as distribution node. (just a guess from what you said)
I can't agree with removing it or that 4wd cars do not require a proportioning valve. The p/v is for bias. Even a car w/50-50 weight distribution encounters weight transfer during breaking. As the weight transfers forward, a system w/50-50 bias would now begin locking the rears as there is less weight on the rear tires for traction, thus they skid.
A car w/anti-locks may control this with the system or more likely encorporates the biasing valve into the anti-lock system.
Unless you have aluminum calipers (not just aluminum pistons in those calipers) it is likley that most of the rust came from the calipers but the lines could be jeopordized also.
*** Be VERY careful making modifications and please do more research on those parts and what they do within the braking system. ***
