flashing green light, I tried switching out the relays as indicated in posts, did not work. Bought a new A/C Relay still did not work. The green light stays lit for 2 or 3 seconds, then it starts flashing. It sounds like the compressor starts but kicks out after 2 or 3 secs. There has been some times when I turn it on and it will work for like five minutes. Dont know how thats possible
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
I recall something similar happening to me a couple months ago while it was very hot and humid outside. But eventually the blinking stopped and A/C blew cold again. At 350k miles, I presume it's time I get the freon replaced?
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
I'd at least have the hi/low pressures checked. If it looks like things have leaked out a bit, after 350K miles, I'd probably have the system evac'd, the receiver/dryer (and associated o-rings) replaced, and new refrigerant put in. However, if pressures are still within spec, I'd leave well enough alone.
My friend's 2000 5SFE had the blinking A/C light but also the battery light. Both his AC/Alternator and power steering belts were bad. I think he had about 60,000 miles on the belts.
We replaced them and and the A/C is working fine now.
1997 Toyota Camry LE I4
@ 193,000 miles
Had the same here. No battery light in my case, but blinking A/C light. First started doing it when it rained which clued me to the belt.
I took in my car to the shop, it had an oil leak that was coming from the side wall. I told them to replace the water pump, timing belt, Tensioner, and a lot of seals. When I got my car back it sounded great, and a rattling sound that was coming from the passenger side of the motor was gone. Also the A/C was fixed. The A/C light stays solid, don't know what it was but i'm pretty sure it had something to do with that rattling.
The Following User Says Thank You to vertigo14k For This Useful Post:
