does Lexus IS200 rims fit my toyota camry 1996 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2010, 10:33 AM   #1 (permalink)
View martin007's Photo Gallery
Red face does Lexus IS200 rims fit my toyota camry 1996
hi,
I think this question is repeated some where in this fourm, does this rims 17" x 7" +50mm offset (PCD - 114.3mm x 5 hole & Centre Bore Diameter = 59mm) fit my toyota camry 1996
Tyres are: 215/45ZR17. original Lexus IS200 rims
sorry I don't knew my hole & centre bore diameter , can anyone help me?
regards
martin007 is offline   Reply With Quote
Old 04-22-2010, 12:25 PM   #2 (permalink)
PortugalFocus's Avatar
Gameroom cash: $124395
View PortugalFocus's Photo Gallery
The bolt pattern is correct. I don't know about the offset though or center bore.
PortugalFocus is offline   Reply With Quote
Old 04-22-2010, 02:50 PM   #3 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
4 banger or 6 cylinder?
RU2CHKN is offline   Reply With Quote
Old 04-22-2010, 05:50 PM   #4 (permalink)
thank you
Old 04-22-2010, 05:52 PM   #5 (permalink)
my car is 6 cylinder, toyota camry vienta
thank you
Old 04-22-2010, 06:22 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
they should fit fine. however, 50mm is a little high. you will be better off if you get some 5mm spacers on there. center bore shoudl be the same unless there is a differance with the IS200.
why does that matter?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-22-2010, 07:48 PM   #7 (permalink)
thank you, I found this pic in this forum. this is the same rims that i need to buy and the same car of mine with the same color . sorry, how can I get some 5mm spacers?, i don't understand this point
Old 04-23-2010, 12:35 AM   #8 (permalink)
1MZFE Marauder
View MrKrispy1183's Photo Gallery
^You can purchase some H&R or Ichiba wheel spacers from a local retailer there in AU. The reason they are being brought up is that the wheel by itself could potentially rub in the rear of the car due to the high offset. The wheel spacers would help alleviate that.
-Brian
MCV20 Solara: Injen/UPFD/GReddy/TRD/Megan/WORK equipped
MrKrispy1183 is offline   Reply With Quote
The Following User Says Thank You to MrKrispy1183 For This Useful Post:
martin007 (04-23-2010)
Old 04-23-2010, 02:51 AM   #9 (permalink)
thank you, I got it , I will buy them first
Old 04-23-2010, 01:51 PM   #10 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
this made me
it being +50mm and getting +5mm spaces will make it effectively +45mm offset which will push it out a bit more further. I agree with bigbird that +50mm offset is a bit high for gen3 camry's. hope this helps
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
