oil leak somewhere around the timing belt.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2010, 09:23 PM   #1 (permalink)
View sc2dave's Photo Gallery
95 5sfe. I'm having a oil leak somewhere around the lower passenger side of the engine.What do i need to replace? I believe it's the result of a false oil seal and the additives cleaned it out(maybe)
sc2dave is offline   Reply With Quote
Old 04-22-2010, 09:39 PM   #2 (permalink)
stingraycamry1996's Avatar
View stingraycamry1996's Photo Gallery
sounds like the leak i had on my 1993 camry, it was the oil pump seal, one garage quoted me $1300-$1500, i found a garage that did job and even changed the timing belt for $260
shop around for the best price and if it is the oil pump seal leaking see if your timing belt needs to be replaced since they have to take it off anyways to do the job.
1996 Camry DX 2.2L 280 000 km ....SOLD
2002 Camry LE 2.4L 109 000 km ....Running strong
stingraycamry1996 is offline   Reply With Quote
Old 04-22-2010, 11:43 PM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Oil pump o-ring, o-pump seal, crankshaft seal, camshaft seal -- they're all in that area, and they all will leak after a while. The oil pump o-ring tends to be the first to go (under the greatest pressure, I guess).
