First, I have to say this is my very first time installing a keyless entry in a car. I got this aftermarket kit (non brand name, model #: CK-009 . 13P) from eBay for $29 and putting it in my 98 Camry LE with standard factory power locks.
I need help in understanding if 98 Camry only works in "Positive Trigger" or "Negative Trigger" or "Positive and Negative Trigger" way. Listed in the instruction diagram in
here.
To start, I follow the procedure listed from several online reference, which all agrees to
this easy to follow link. I only connected the followings:
- DarkBlue & DarkBlueWhite for lock & unlock (from the orange plug below fuse near driver kick panel),
- Red/White (from ignition switch harness),
- Black (grounding point near driver kick panel).
Here's the part that troubles me, I connect it via the positive trigger way, the power lock may response to the remote sometimes, other times I just hear the signal going through the keyless module as it's trying to do something. Unlock doesn't work at all. I see LED light blinks like it should on the keyless module.
Then I use more wire snapper to connect via the Negative Trigger way, nothing work, except I see the LED light blinks like it should on the keyless module.
Any help or insight would be greatly appreciated!
