Camry 5SFE spark plug heat range - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2010, 07:19 PM   #1 (permalink)
View toyota1971's Photo Gallery
Australia Camry 5SFE spark plug heat range
Hi Guys.
Has any one fitted one number hotter spark plugs to 5sfe engines?
I have set of Denso IK16 spark plugs with me but recommended heat range is Denso 20.
If i install IK16's any bad will happen?
Cheers...
toyota1971 is offline   Reply With Quote
Old 04-24-2010, 07:36 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Lower number is a hotter plug, with risk of knock you will get better efficiency.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 04-25-2010, 05:57 PM   #3 (permalink)
I installed the spark plugs.I can clearly see a fairly big performance improvement.Can not hear any engine knock.Possible because of ECU controlling the timing.
Old 04-25-2010, 10:47 PM   #4 (permalink)
View sc2dave's Photo Gallery
do 95's have knock sensors? 5sfe
sc2dave is offline   Reply With Quote
Old 04-26-2010, 03:49 PM   #5 (permalink)
[quote=pgmomni;3172147]and unless the original plugs where in perfect shape, changed plugs always results in improved performance.
why did you choose hotter plugs?
Because i got a set of Denso IK16 with me.
Old 04-27-2010, 01:18 PM   #6 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
You might just pull those out and inspect them for deposits. . . .
Need to follow some rules to get the most value out of your time though.
With a warm engine, run it at near full throttle under a load (in gear pulling down the road) and then turn it off as quickly as you can safely pull over off the raod to a safe spot.
Remove the burning hot spark plugs and inspect them very closely.
If the tips of the electrode have tiny metal balls on them or the porcelain is bright white, they're too hot and will cost you gas mileage and engine performance. Because the modern engine checks for listens for cylinder detonation, you may not see the shinny little balls right away as the timing will retard if detonation is detected which will reduce this tendancy, but you should look for them.
If the above is not an option pull them after a brisk drive and look them over in the driveway. It should give you an idea to how things are looking. Compare to the chart below (link attached).
Regards,
73
Tune Up, Spark Plug Condition link
All,
Here a is link to identify various spark plug conditions to aid you in your tuning and diagnostic trouble shooting.
http://www.ngksparkplugs.com/tech_su...ad.asp?mode=nm
73sport is offline   Reply With Quote
Old 04-27-2010, 03:49 PM   #7 (permalink)
Thanks 73 Sport.Very informative...
