differntial and transmission drain&fill plugs size and type - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2010, 10:53 PM   #1 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
4th Generation differntial and transmission drain&fill plugs size and type
Hi,
what size and type are camry's gen4 (auto, 4-banger) tranny and differential drain/fill plugs ? are they hex bit or torx bit, what size ?
thanks.
Old 04-24-2010, 11:05 PM   #2 (permalink)
View gyjoe's Photo Gallery
On my '98 I4 the transaxle has a 10mm hex key drain plug and a 17mm hex bolt refill plug. Can't recall what size the hex key drain plug is on the pan, though.
gyjoe is offline   Reply With Quote
The Following User Says Thank You to gyjoe For This Useful Post:
fenixus (04-24-2010)
Old 04-25-2010, 12:51 PM   #3 (permalink)
View Rattlin_Steele's Photo Gallery
Both the differential drain and the transmission drain are 10mm hex key.
Rattlin_Steele is offline   Reply With Quote
The Following User Says Thank You to Rattlin_Steele For This Useful Post:
fenixus (04-25-2010)
Old 04-25-2010, 01:14 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
thanks guys!
Old 04-25-2010, 01:49 PM   #5 (permalink)
Gameroom cash: $123900
View dave1811's Photo Gallery
Smile
There is a good DIY link here on the TN about changing the differential fluid with good pics.
DIY : Differental Fluid Change
Dave
99 Camry (141k miles-At the graveyard now!)
99 Camry (161k miles)
02 Sienna
dave1811 is offline   Reply With Quote
Old 04-25-2010, 03:32 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah i know that one, thanks
just didn't know all hex bit sizes i need for both tranny pan drain and rest. was trying to get a nice 9pcs hex bit (metric) set 3/8'' & 1/2'' from HFT. wanted to make sure it fits both applications.
