Removing power window regulator
Hi,
My car is a 96 Camry sedan. The driver side power window does not work. It stopped working when the window is fully closed.
I just followed the instructions in FAQ. After removing the inside door panel, I tried to pull down the window so I can detach the glass from the regulator. I pulled the wire of the regulator down by hands but it's very tight so the glass did not move at all. Then I cut the wire and pulled it down again but it does not help. Did I miss something here? Or the regulator/glass gets stuck by something? Thanks.
