Cali vs Federal - differences in exhaust manifold? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2010, 04:18 PM   #1 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
Hey guys,
Do you know if the the californian RH exhaust manifold fit to federal car?
OEM part no: 17140-20010 - federal, 17104-20010 - cali.
On picture the Californian manifold looks the same:
Will it fit to my federal camry that uses 17140-20010?
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 04-26-2010, 05:07 PM   #2 (permalink)
1MZFE Marauder
View MrKrispy1183's Photo Gallery
Edit: Not sure, as I'm more familiar with the Gen 4 design.
-Brian
MCV20 Solara: Injen/UPFD/GReddy/TRD/Megan/WORK equipped
Last edited by MrKrispy1183; 04-26-2010 at 05:08 PM. Reason: Different Gen is more my knowledge
MrKrispy1183 is offline   Reply With Quote
The Following User Says Thank You to MrKrispy1183 For This Useful Post:
Nervous (04-26-2010)
Old 04-26-2010, 05:23 PM   #3 (permalink)
Nervous's Avatar
Well, this manifold on the picture is from Camry 98. THe only difference I see between cali and not-cali part is that additional bracket and bolt on the left side of y-pipe port. I guess, the metal saw will convert it to federal pretty easy
Old 04-27-2010, 10:22 AM   #4 (permalink)
Nervous's Avatar
Interestingly, why californian part costs less than federal, btw (at dealer)? And I am still not sure if it fits or not. There is a good deal on ebay for the californian manifold and I am hesitating to jump into it......
Old 04-27-2010, 11:08 AM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
i would be careful, ask for real pics of california manifold from seller and compare with the federal one you have (?).
atl least 5s-fe gen4 camry has different exhaust manifolds. location of o2 sensor hole is different, besides 5s-fe california has cat converter in it while federal doesn't. i guess at least this one is not the case with 1mz-fe.
The Following User Says Thank You to fenixus For This Useful Post:
Nervous (04-27-2010)
Old 04-27-2010, 11:11 AM   #6 (permalink)
Nervous's Avatar
The picture above is the actual pic of the californian rear manifold and it really looks the same beside of that additional bracket and bolt on y-pipe port....
Old 04-27-2010, 11:14 AM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
make sure you can send it back if it doesn't fit
