Hey guys,
I have a few questions about replacing the motor/trans mounts on my 93 Camry LE V6, auto trans. I searched the site and read every single thread in this section with the word "mount" in it but didn't see any DIYs for the 3VZ. I would like to help create one with pictures, but I'm having trouble locating the rear mounts.
Here are the pictures of the parts I purchased:
I swear I went under the motor (below where the dog bone is) and I can't see anything that resembles this. Is it mounted sideways on the cross member? That seems like it would make the most sense.
This looks very similar to the one above, so I'm hoping I didn't get tricked into buying the wrong/duplicate part. Again, I looked on the bottom rear of the motor (under dog bone) as well as around where the trans sits, but can't find any part that looks like this. Can somebody verify that these 2 parts are correct and actually separate parts?
I know exactly where this one is located, it's just a pain to get to the lower bolts, and the top bolts won't turn at all. For some reason the socket just doesn't seem to get a tight grip. Any tips/suggestions on that?
The good ol' dogbone. I actually replaced this about a month ago and it's already shot. This is why I know I need to do the lower rear mounts as well. It's a simple job, actually, only took about 15 minutes.
My engine shakes pretty bad, so to be safe I'd like to replace all the mounts. Are there any others that I should do while I'm doing this?
Also, should the jack with the wooden block be placed on the oil pan (away from plug) for all of these mounts?
I already replaced the front one (pictured below) about a year ago and it's still holding strong.
When I do this job I'm bringing my camera with me so I can create a DIY on here for everyone. Any other tips/suggestions would be very much appreciated, but most importantly I'm searching for the location of the 2 rear mounts and they have been elusive thus far!
Thanks!
