99 Solara 2.2 cranks, wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2010, 07:51 PM   #1 (permalink)
View brandonb1369's Photo Gallery
I was driving last week and my car suddenly died out on me. I found out that the timing belt had broke. After replacing the timing belt, other belts, water pump, timing belt tensioner and idler pulley, I cranked the car over and it still wont start. I pulled all 4 spark plug wires and I get a spark from all of them. You can smell fuel while trying to crank it over. Any ideas as to what the problem could be?
brandonb1369 is offline   Reply With Quote
Old 04-30-2010, 07:58 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Recheck timing, its probally off.
carsrus is offline   Reply With Quote
Old 04-30-2010, 09:32 PM   #3 (permalink)
View finfinder's Photo Gallery
what he said.
finfinder is offline   Reply With Quote
Old 04-30-2010, 10:36 PM   #4 (permalink)
View 69GTSport's Photo Gallery
Yep, check the timing. I'd read the sticky which has a few threads discussing timing belt replacement. You'll see also that it's possible to set the timing to the wrong "timing marker" located behind the cam sprocket...
1999 Toyota Camry XLE V6.
1995 Toyota Camry LE 4dr. 2.2L.
2009 Harley Davidson Dyna Superglide Custom, customized to suit my tastes .
69GTSport is offline   Reply With Quote
Old 05-01-2010, 08:27 PM   #5 (permalink)
Gameroom cash: $106355
View Fortified Souls's Photo Gallery
x3 lol the knock pin should be at 12o clock at TDC and if you have the valve cover off there will be dots that should be lined up at that position.
look in my thread for more info
Questions on starting camry recently rebuilt.
Fortified Souls is offline   Reply With Quote
