95 Igition lock cylinder replacement
Ok did some searching and did not find the answer.
95 Camry needs a new ign. cylinder. I under stand how to get the cylinder out by pushing the pin and pulling it out in acc position. I have removed the lower cover under the steering wheel. I can see the pin and such but what about the glowing bezel around the ignition key cylinder it self? Does it just come out with the cylinder when you pull it?
I dont want to break anything 15 yearold car.
thanks
James
Arguing online in forums is like being in the special Olympics, you may win but your still retarded.
