hi guys!
ok... so i have an automatic 94camry with the 1mzfe and i got a lack of power issue...
i searched this forum with the keyword i had in mind and found out about the knock sensor thread from eye8pussies, i'll get back to that
first of all i'm going to describe the problem and tell you what i've looked at...
when the car is cold-warm i have HORRIBLE acceleration from a dead stop... when the car heats up i gain some power but again from a dead stop i have shitty acceleration... and overall i feel like the car lost power from when i first got it...
-spark plugs has been changed (stupid rear bank!)
-trans oil was changed (15liter)
-injectors were cleaned using the aluminium canister plugged to an air compressor...
-throttle body was cleaned
-cone air filter cleaned
-compression is about 155 psi
-fuel pump puts out about 35-38 psi
- vacuum is at about -22hg
-no check engine light
-plugged a snap-on scanner and all parameters looks ok (injector trim and blablabla) no misfire on any cyl
-did a stall test and engine locks at 2500rpm
-fuel comes out of the filter very clean (anyway i got another bnib one to install)
- coils are on spec... haynes manual says .5 to .85 ohm and they are reading .8ohm
-no exhaust backpressure
throttle body position sensor is reading 70% open when at WOT i've been told that its not that important and to leave it alone... WTF! to me it looks kinda important!?!
-while having the pedal to the floor the engine then engine accelerates slowly then at 4000 rpm it changes sound and accell harder (i kinda found out it was due to a valve opening in the plenum to allow more air...)
i was looking at eye8pussies's dyno graph before he moved the knock sensor and it looks VERY simillar to the one i obtained from my ipod touch...
look at the first graph on his thread
http://www.toyotanation.com/forum/t158255.html
and look at my graphs
looks like i got something going on no?
thanks for reading my loooooooong post
