You will have to remove the frame around the stereo/ac controls. I believe you have to pull up the trim from the shifter also. Most of the screws are hidden behind those items. There are two other screws also. I think one of them may be hidden behind the edge of the glovebox, and the other one is behind the edge of the large plastic panel under the steering wheel. I could be wrong about any of this. I removed the center console a few months ago but I don't recall exactly where all of the screws were. It's do-able.
You will have to remove the rear (armrest) portion before you can pull the front part out. Be very careful separating the two. It's very east to break the little plastic pieces holding the two together. To my recollection, the armrest half pulls straight UP.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
