92 camry no Spark? igniter maybe? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2010, 06:07 PM   #1 (permalink)
View larocque44's Photo Gallery
Washed the engine bay sat morning let it dry for about an hour started and ran fine. started it about 2 hours later and it ran for about 10mins then died.
Tried starting it several times and nothing turns over and is getting fuel, i suppose i can smell it. Pulled a plug and there is no spark. Car has 213000km on it and runs good has Custom CAI, and custom grounding kit both have been on it since i got it. My father thinks it is the igniter. Is this a common problem or has anyone had this happen to them.
New to this forum and any help that would point me in the right direction would be of great help.
Travis
larocque44 is offline   Reply With Quote
Old 05-02-2010, 06:56 PM   #2 (permalink)
Gameroom cash: $303255
Which engine; I4 or V6 and how many miles on it?
In either case, take the distributor cap off and try to dry the underside of the cap and the distributor itself with a hair drier. Then reassemble the cap and try to start the car. If it still doesn't start, I would next check the coil inside the distributor. The coil causes a lot more problems than the ingitor on these cars, especially when they rack up lot's of miles on them. To check the coil you will need a digital volt/ohmeter and the specs from any manual. If you don't have a manual you can download one for free at the top of the Camry forum, over at AutomotiveForums.com. Download the generation 3 manual. Also remove the coil and inspect it carefully for cracks, even if it specs out OK.
Mke
Mike Gerber is online now   Reply With Quote
Old 05-04-2010, 05:19 PM   #3 (permalink)
igniter specs out ok im going out to pull the coil and see whats going on and test it. I was going to just go get a used distributor and see if that fixed the problem seeing as im having to bum rides off my old man to get to work its getting frustrating. Thanks for he help ill see what comes up and post it.
Old 05-04-2010, 06:12 PM   #4 (permalink)
So pulled the coil out and it has a crack around the outside of the screw hole. i didnt think that would have caused the engine to no longer get spark with that size of crack but there has been a coil on order for the past week just in case. I hope this solves the problem
Old 05-04-2010, 06:51 PM   #5 (permalink)
It probably will.
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
larocque44 (05-08-2010)
Old 05-08-2010, 03:18 PM   #6 (permalink)
Car is running better than ever thanks for the help
Old 05-08-2010, 04:25 PM   #7 (permalink)
You're welcome.
Mike
