Transmission pan torque specification - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2010, 09:44 PM   #1 (permalink)
iamanewbie
View pritongmanok's Photo Gallery
USA Transmission pan torque specification
Camry manual says transmission pan torque is 43 in-lbs. However, the instructions which came with the rubber gasket that I bought said to apply 120 in-lbs.
Initially, I applied 43 in-lbs. But the transmission pan leaked. Should I follow the gasket instructions instead ?
Any help is appreciated.
pritongmanok is offline   Reply With Quote
Old 05-02-2010, 10:44 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $952415
iTrader Score: 16 reviews
Welcome to Toyota Nation!
Let us know what year your Camry is and we'll move your thread to the appropriate forum
Kiwi-Corolla is online now   Reply With Quote
Old 05-02-2010, 10:59 PM   #3 (permalink)
iamanewbie
My car is Camry 1998 4-cylinder.
Old 05-02-2010, 11:11 PM   #4 (permalink)
Full Throttle
Cool. I've moved this to the Gen 3 & 4 Camry forum for you. These guys know Camrys better than anyone . Best of luck.
Old 05-02-2010, 11:37 PM   #5 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
My advise it so go by feel on these bolts. Use a 1/4" drive ratchet and tighten up the bolts until you feel resistance, then turn it a 1/2 turn or so more. It takes a bit of practice, but just remember to use a light touch. Run the car for a day, go back and snug up the bolts again (they tend to come slightly lose after running for a bit), then leave them.
Whatever you do, resist the urge to keep tightening the bolts over and over again if the gasket leaks, it will bend the pan eventually and ruin it. If the gasket keeps leaking, it's either a poor quality gasket or something else is wrong.
71Corolla is online now   Reply With Quote
Old 05-02-2010, 11:43 PM   #6 (permalink)
View Rattlin_Steele's Photo Gallery
And also make sure you spread out the tightening sequence evenly around all 15 (IIRC) bolts and that the mating surfaces are extremely clean. Hopefully you don't already have a bent pan that's causing you problems. 120" lbs sounds a bit high IMO. I believe the spec is 48.
Rattlin_Steele is offline   Reply With Quote
Old 05-03-2010, 11:15 AM   #7 (permalink)
iamanewbie
Thanks for the advice. Both comments above were extremely helpful. I tightened the pan bolts a little bit, drove a few miles, and leak decreased considerably. I tighted bolts a little more, drove a few miles, and leaked stopped. In short, PROBLEM SOLVED - CASED CLOSED !
Maybe I should just use RTV next time instead of a gasket so I don't need to tighten the bolts as much. I'm afraid that I might strip the threads or damage the pan next time. I did not use RTV this time because I spent a lot of time removing the old gasket and RTV. Is using an RTV better in my situation ?
