I finally got it to start thanks to another thread on here. Seems as if I had the cam's misaligned when I reinstalled them. It started right up but now overheats, looks like the water pump or thermostat are bad. I also have a worse top end knock now than I did before I replaced the head. I'm hoping that the valves just need adjusting or I've wasted a lot of time and money.
Does anyone have any suggestions on how to check the valves and make any adjustments needed? The reman head was "supposed" to be adjusted already.
No CEL or anything, just a bad knock and overheating.
