Driver Side Door Wiring? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2010, 06:39 PM   #1 (permalink)
View Darkshowdo's Photo Gallery
So New Speakers And my Driver side does not work still.
Took alligator clips right up to the stero, and it works fine, so somewhere within those wires from stero to Speaker is a problem,
Maybe its why my Passenger side windows dont work either.
I check under my kick panel everything seems connected in that Blue box thing. i check for wires that are broken.
Couldnt find anything i was going to check the rubber thing that connects the door n Frame of car, But i have no clue how to get it off.
Plus i have no clue where the problem would really be.
Im guessing it within there, but seeing the wires are rapped in this stuff. i figures its impossible to know.
Anyone have any clue or experienced this?
I was gonna run my own wire but thats also impossible.
Darkshowdo is offline   Reply With Quote
Old 05-04-2010, 07:13 PM   #2 (permalink)
View skuttduck's Photo Gallery
Test for continuity.
At work I usually pick up our fluke meter. So you would want to pull out the stereo and touch one end to the drivers side positive speaker wire in the factory harness, and then the other to the positive spot on the speaker.
Do the same with the negative and see which one or both of the wires are broke.
I've also heard of testing speakers by using a 9 volt battery. You should hear it pop when you hook it up.
I think your guess about the wire being shorted inside of the gasket in the door is the most likely culprit.
skuttduck is offline   Reply With Quote
Old 05-04-2010, 07:23 PM   #3 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
View Bankos66's Photo Gallery
^+1 Maybe one of your wires is cut somewhere that you don't see. I guess I got lucky when I put my Pioneers in that it worked right away
1994 Camry V6 XLE -- Totalled
1995 Lexus ES300
Bankos66 is offline   Reply With Quote
Old 05-04-2010, 07:28 PM   #4 (permalink)
I just bought brand new speaker i was putting them in thats why i posted this cause they still dont work well driver side doesnt.
I tried doing this Putting my meter on OHMS n testing for n were the wire would be broke but no signs, just readed 1.
I tested the wired for power
the Stero is giving power if i hook the Speaker right up using alligator clips to the speaker it works fine.
As i think you are right about it being in the gasket now is it a easy fix? cause i think all the wires are wrapped in this stuff to make it impossible to get to.
or should i just have a mech. do it for me?
Yeh im guessing there cut somewhere but Its not at my kick panel or in the stero compartment rest of the wires are just covered so i cant see them rest cause they go into the driver door.
Old 05-04-2010, 08:03 PM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Check for continuity, which you've done. Check for broken wires in the rubber boot in the door. Don't start new threads for the same issue. I think that's it.
'07 Honda Ruckus Big Bore
Old 05-04-2010, 08:28 PM   #6 (permalink)
so then how i get the rubber boot off?
Old 05-04-2010, 08:31 PM   #7 (permalink)
Freakin Scooters
^ Good question. After you have the door panel off, take a look at where the boot connects to the door. I'm sure you can figure it out.
Old 05-04-2010, 08:54 PM   #8 (permalink)
what?
ive taken it off meny time and i cant even see the other side of the boot? All i see is the Boot connecting each side of it, Do i just pull it out from the connection in the middle?
Old 05-04-2010, 09:23 PM   #9 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
Dude if it was me I would just screw around with all the wires and rewire it all over again just for fun im an idiot
1995 Lexus ES300
Old 05-04-2010, 10:13 PM   #10 (permalink)
Freakin Scooters
Originally Posted by Darkshowdo View Post
what?
Take off the door panel. Take off the kick panel. Look at the boot. Decide how to remove it. (My guess is that it will just pop out of the door with some force.) Remove the ends of the boot connected the door to the kick panel.
Stop being me, Bankos.
Old 05-05-2010, 05:18 AM   #11 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
^ lol I love being u
1995 Lexus ES300
