air conditioning mismatch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2010, 12:32 PM   #1 (permalink)
View catmandu's Photo Gallery
Been searching for a while, can't find a similar thread anywhere:
I have a 2000 LE 4cyl. The left and left center vents blow 15 degrees cooler than the right center and right vents when the a/c is on. Don't notice a difference with the heater. Problem?
catmandu is offline   Reply With Quote
Old 05-05-2010, 12:39 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Normal. For every car I've ever been in. Always wondered why.
'07 Honda Ruckus Big Bore
The Following User Says Thank You to LynchburgCSI For This Useful Post:
catmandu (05-05-2010)
Old 05-05-2010, 12:49 PM   #3 (permalink)
Okay then. That makes all three issues solved today (new struts to get rid of bearing rattle, lubed lower steering knuckle to get rid of hard spots in the steering, and a/c charged to accepted performance!)
Thanks!
Old 05-05-2010, 12:56 PM   #4 (permalink)
Freakin Scooters
No problem!
Old 05-05-2010, 01:39 PM   #5 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
It's because how the blower works and how the distribution tubes are laid out.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 05-05-2010, 08:21 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
it's normal when you are low on refrigerant in system. i had same thing twice before i took it to a shop for professional vacuum (it removes moisture form system) and recharge.
Old 05-05-2010, 08:31 PM   #7 (permalink)
First noticed this end of last summer by 'feel'. After our first humid stretch of days last week I was notified by m'lady that the a/c 'sucks'. So as part of today's shop fun we put 5.5 ounces of coolant in, as well as some dye just in case. The 15 degree difference was after the recharge.
Seemed to chill pretty well driving around today, but it is pretty nice out temp and humidity wise, so we shall see.
Thanks all for the help, this place is on par with the f150 site for helpfulness, which is good since both those vehicles are topping 200k!
Old 05-05-2010, 09:46 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
i eventually replaced the drier receiver tank (by radiator) which was the source of leak in my case. not sure if it healed the escaping gas problem for long (i heard all a/c systems loose coolant sooner or later even with no visible leaks), but it's much better now. i did when i was to go to shop for recharge the second time.
adding refrigerant from can is not really recommended in a long run if you have bigger leak (how fast does it become low on gas again ?). reason is that a/c system contains oil also which lubricates the mechanical parts (compressor). when you have a leak you loose also that oil together with gas and then when you keep adding only gas .. well at some point compressor starts running dry and eventually dies.
Old 05-05-2010, 10:54 PM   #9 (permalink)
Freakin Scooters
Guys he just recharged the A/C system. IF it gets worse, then i'm sure he'll chime back in. That would of course, indicate a leak.
Old 05-05-2010, 11:49 PM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
right
Old 05-06-2010, 06:19 AM   #11 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
How did you know it needed 5.5 oz? Overcharge just as bad a under charge, maybe worse if pressures get too high. Can't properly diagnose or fix A/C without gauges.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-06-2010, 06:32 AM   #12 (permalink)
Some guy I met in the automotive aisle at WalMart says he always just adds 5.5 ounces every year and his cars work real good. He said to get 5.5 ounces, you open the valve on the can of a/c cold maker stuff for ten mississippi's. He said his cousin taught him this trick, and his cousin used to work on tanks in the Army, so he knows stuff.
Sorry, too much coffee, just funnin' with ya: My Uncle's "got a bitchin' set of tools" has all the good stuff to do this (and most things) right, buys 134a 30lbs at a time (the fun the day before was replacing the compressor on the neighbor's 2000 MB wagon).
Old 05-06-2010, 10:02 AM   #13 (permalink)
Freakin Scooters
^ credible source ftw.
