Originally Posted by relgalf
Thanks, what would the costs be to have a mechanic do this?
Honestly, even if you're only slightly mechanically inclined you can do it yourself. You have to take out the Instrument panel, radio, glovebox, lower dash, gauge cluster, then you can unbolt the dash, which is like 10 bolts, and slide it forward enough to fix it. It's really not a lot of work. Just purchase a repair manual and you should be able to do it.
It cost me about $5 for a bottle of cement glue to fix it. A mechanic would probably charge you anywhere between $500-1k to fix it.
