use deep 19mm socket with long extension to allow more free space to remove ECT sensor. this is just a reminder. Before you plan to remove ECT sensor, take your 19mm deep socket and insert on your new ECT sensor to see if it fit before you proceed (remove old ECT sensor).
Be careful remove the snap (2-wires that go into your old ECT sensor) without break it. you have to press in clip and hold while gently pull off.
you have to look and remember how your old ECT sensor position before you remove it. next, you install your new ECT to the same position. Pre-tight with your hands before use 19 mm deep socket.
