i did the same thing... and had to replace a broken hinge. you must remove the bolts on the quarter panel. you don't have to remove the whole quarter panel, just take off the bolts which hold it down. this is enough to move the panel out of the way to unbolt the hinge. there are screws in the wheel well, a bolt in the door jam above the door hinge, and there are some bolts holding the quarter panel down that are on top of the panel right below the edge of the hood where it closes. i think you might also have to remove a piece or two by the windshield wiper.
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
