When and where to get tire alignment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2010, 10:32 PM   #1 (permalink)
View schumionbike's Photo Gallery
I just recently had all 4 of my tires changes at Walmart. I heard that you should get an alignment when ever you change your tires. Well, turn out Walmart doesn't do alignment and neither does Discount Tires which is odd. Anyway, it is absolutely necessary that you get an alignment when you replaces your tires? btw, I didn't really notice that the old tires were excessively worn on one side or anything. It's hard to make sure if the my track is straight cause the road is always crooked so it's hard to tell, nothing seem really off though.
Second, I live in the south Houston area (Pearland), where do you guys reccomend for alignment services? The only place I know is Firestone Tire, they have this lifetime alignment thing which seem to be an overkill, it doesn't seem like you need to get an alignment every 6K miles. Anyway, let me know if you have any recommendation as to where to get it done. Thanks.
schumionbike is offline   Reply With Quote
Old 05-07-2010, 10:36 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3626750
Given the number of potholes hit, curbs accidentally driven over, etc., it adds up over the life of a set of tires. IMO it ought to be done as a matter of course with each new set, and that would be for both axles. Opinions vary, but I'd say get it aligned.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 05-07-2010, 10:56 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Well, getting an alignment when you get a new set of tires (every 40-60K miles?) helps to prolong the life of the tires. Primarily because it's a convenient time to try to catch alignment issues, but not a mandatory time to do so.
Swapping old tires out however also takes away the signs the shop can use to determine alignment problems.
But I think it's a good idea to get an alignment at least once after the first 24-30K miles. The reason is that the suspension components (coil springs for example) settle down and sag a bit. If you notice unusual wear patterns then do it as necessary. Sags typically change alignment angles.
I'd find one using a later model Hunter equipment. Check references from tuner friends I guess. They should know where good shops are.
http://www.hunter.com/PUB/product/AL...TEMS/index.htm
Old 05-07-2010, 11:00 PM   #4 (permalink)
See our V6? I wish...
tht1gurl's Avatar
Gameroom cash: $115750
View tht1gurl's Photo Gallery
You've got a Midas:
http://4401broadway.midashoustontx.c...language=en-US
^I would recommend Midas, my mom goes there for her car maintenance. They treat her well and are on a first name basis; I will acknowledge the possibility that your Midas may not be as homey as ours is.
http://brakeandalignment.com/
^The website is under construction but I think they're worth checking out if they claim to be specialists in this area.
http://www.brakecheck.com/index.php?...per&Itemid=112
^Look at the right sidebar and you'll see that they do alignment checks.
I always say, the way a man treats his car is how he treats himself.
You take care of the car and the car will take care of you.
tht1gurl is offline   Reply With Quote
Old 05-07-2010, 11:07 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
for wheel balancing it's easy, go to www.tirerack.com and pick Recommended Installer link somewhere over there. then by zip code you get the local ones and can see details about each including machine type and model used for installation and balancing.
for wheel alignment i usually go to Firestone, last time used them with a set of new tires, paid $75+tax for alignment of both axles. not sure what equipment they have, but they do it good, usually lasts 3-4 years unless i start hitting potholes like crazy.
Old 05-08-2010, 04:47 AM   #6 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
I get free lifetime alignment at FireStone for my Camry!......Anytime, as much as I need it!.....For the life of my car! Which will be a very long time!....
ricamryman is offline   Reply With Quote
Old 05-08-2010, 07:20 AM   #7 (permalink)
View importcar's Photo Gallery
How mch do you pay for lifetime alignment?
2001 Camry LE 5S-FE
importcar is online now   Reply With Quote
Old 05-08-2010, 07:52 AM   #8 (permalink)
I'm debating the Firestone deal too, I think the lifetime alignment cost a good 170 or so versus 70 for standard 4 wheel alignment. My car have 182 on it and I don't know how many alignments I'm really going to need.
Old 05-08-2010, 11:16 AM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
last time i was in firestone they had lifetime alignment deal at $139 on promo, i didn't take it tough haha...
Old 05-08-2010, 01:10 PM   #10 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
http://www.firestonecompleteautocare.com/offers/
FREE Alignment Check* + 15% Off Standard or Lifetime Wheel Alignment
*Free alignment check with tire purchase.
Offer valid from May 1-31, 2010
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 05-08-2010, 04:27 PM   #11 (permalink)
3rd Generation
I paid approx. $140.00 a year ago! Had three alignments since!....
Old 05-08-2010, 05:10 PM   #12 (permalink)
So I went to Firestone today, I actually had that coupon too but it's not valid because I didnt' purchase any tires. The guys told me that the car inner tie rod is worn and need to be replace and that the alignment can on got so far this time. The price they give me was 478 before tax which I thought was steep, so I decline the work. Any recommendation on this issue?
And yes, 140 for lifetime alignment but this might be the last alignment for the car
Old 05-08-2010, 08:11 PM   #13 (permalink)
3 times in a year? So what happened?
Old 05-08-2010, 08:18 PM   #14 (permalink)
抵抗は無駄です
fenixus's Avatar
man i usually do it when changing tires every 4 years or so, you might need to replace some parts if alignment gets screwed up so often
Old 05-08-2010, 08:22 PM   #15 (permalink)
Do you feel the steering is loose in your daily driving?
Turn the wheel full right to gain access to the left tie rod. Grab the tie rod and try to move it in/out/up/down/left/right. And hold it with an assistant trying to turn the steering wheel back and forth (engine off, parking brake applied, necessary precautions, etc etc). Do you feel any play in the tie rod? Do the same on the other side.
You just have to make sure the tech didn't have a sales quota to meet. You can always get a second opinion. If the inner tie rod is bad, you might as well replace the whole steering rack. You can order a reman rack from an online Toyota dealer or get an A1 Cardone with lifetime warranty. Not sure if dealers source from Cardone however.
http://www.cardone.com/English/Club/...ht/default.asp
The Following User Says Thank You to JohnGD For This Useful Post:
schumionbike (05-08-2010)
