Originally Posted by Mike Gerber
If the car does turn over, hold your foot to the floor while cranking (turning it over). That's the proper way to start a flooeded engine, which is probably what you are dealing with with all that seafoam in the system. DFon't be surprised if it starts and dies a few times. After you get it idling reasonably well, take it for a ride for about 10-15 minutes to clear all the seafoam out.
Mike
+1
it takes some revving to start it up after sea foam. floor the gas pedal to initially start the engine then hold it at 2,500 rpms for a little until engine start running more normal. it may still die at idle a few times, don't worry. there will be lots of white smoke once started after sea foam, don't be afraid of it. it will take a few high rpm runs to get rid off it.
