I have a noise coming from the crankshaft pulley area of my car that I can't figure out. It is mostly only during warm-up, and dies down almost completely once warm (however does not lessen on warm or cold days). The mysterious part is that it is not consistent or rythmic, but rather like something is hitting intermittently. It is a flapping/clapping sound, which I've diagnosed as coming from the crankshaft pulley area. I took the right wheel and apron off, and noticed the noise the loudest in that area. The pulley doesn't seem to wobble, and the belts are new in an effort to fix noise (noise still happened, but a bit less, when I took belt off and started up car). Noise originates right around crankshaft pulley - not alternator, not ps pump, not upper timing belt area, not water pump area, not lower or upper central engine area...any ideas what could be making this noise??? Again, once the car warms up, it is only the occasional clap/flap/catch. Makes noise most noticeably during warm-up driving when in park...reduces dramatically but not completely when in gear (d or r). Doesn't seem to be affected by rpm's.
The car is a 1999 toyota camry 2.2l 4 cyl 5sfe auto. tranny w/115k miles w/timing belt replaced approx 45k miles ago.
Please help! Any guidance would be much appreciated!!
Yes, that ticking/clacking sound that you hear mostly in the first half of the video...that is the sound I am getting, but a bit louder and it seems to last a little longer. That lower whirring/thumping sound I am not getting...
I will try and take some video of it today and post a link.
Like I said, I took off the front right tire and apron, started the car up, and could see/hear that it was coming directly from the crankshaft's immediate vicinity - not above or below.
You need to re-tension the timing belt. Turn the engine over manually to get the slack on the tensioner side, the loosen/tighten the tensioner lock bolt.
Brad B.
ABQ. NM
07 DC 4x4 offroad
1981 Unimog 416Doka
Thanks guys. I really appreciate the quick responses. And just to double-check before I go out and get bids or consider doing the job myself...you're sure that it is timing belt flap even if I didn't hear anything any louder with the tb cover cracked open and listening in? Like I said, it sounds very external - right on the crankshaft pulley. I don't doubt your expertise, just making sure.
I will try and get a video posted early this week, or will give an update if something new pops up (literally, ha).
If its timing belt flap you need a new belt. The 5sfe tensioner is set at max once you install the belt, no adjustment.
I was able to re-tension the timing belt on both of my 98 4 cyl. Camry's 5k miles after installing a Toyota belt, and did in fact get a little more travel from the tensioner. I guess I dont understand why there would be an access hole for re-tensioning the belt if the tensioner wont allow it.
Brad B.
ABQ. NM
07 DC 4x4 offroad
1981 Unimog 416Doka
Ok, here is a video i just got done taking. I hope it does the job, b/c there are a couple of issues with the video - 1) the engine noise drowns everything out a little and 2) this noise is most noticeable when cold, and I couldn't wait 1hr + for the engine to cool down. Hopefully this is evident enough! It is the intermittent ticking that can be heard when looking at the crank pulley. Notice that it is not a consistent tick, and also how exterior it is.
Sounds like a bad waterpump to me. Thats a metallic noise. Mine made something similar for a couple months before the waterpump seized.
Take the alt. and ps belts off and run it and see if it stops. If it doesn't I think you have a bad waterpump or idler bearing. Where they replaced when you did the timing belt?
Could it be a balance shaft noise like this person is describing? It's really hard to tell from that video the mic picked up some frequencies too strongly. It does sound like the metallic clatter you get when the water pump is going.
Paul10, dont waste any more time on this until you re-tension the timing belt. If you turn the engine slightly and place the slack on the tensioner side, you will feel the tensioner move to tighten the belt when you loosen the nut. I had one of my Camry's making the same noise and I thought it was the water pump. It was the TB hitting the cover.
Brad B.
ABQ. NM
07 DC 4x4 offroad
1981 Unimog 416Doka
UPDATE: The belt snapped on Friday, and I went ahead and replaced everything over the weekend. Took me about 7 hours and cost $165 worth of parts (belt, w/p, and idler pulleys). My guess as to all of the noises: the clapping noise was a loose timing belt hitting up against the cover, and the metallic noise was the guide on the crankshaft sliding back and forth. Either way, it all seems to be fixed, except that I think I might be a tooth off of perfect timing. That little depression on the camshaft pulley is difficult to see perfectly, especially after a full day of work!
Haha, I'm starting to have the same problem. There was a thread I posted not too long ago where many TN members highly suggested OEM parts, OEM parts, OEM parts. Well, I cheap out and it might have backfire on me.
So I have the same problem and it happens after a timing belt change. The noise from inside my car sounds as if there was a pen or nail clipper bouncing in the door pockets; just random. The noise (when siting in the car) is coming from the timing belt area/corner and is more noticeable at higher RPM. The problem is that the noise only happens if the engine is in gear and under a heavy load.
In park and revving = fine.
Rolling at 40mph in neutral and revving = fine.
Driving around at any vehicle speed with light load = fine.
I basically have to open up the throttle to get the noise; mostly above 3500 RPM.
As suggested to the OP, I might have to re-tension my Gates timing belt (should have brought Toyota) Can the belt stretch after 500 miles? I might as well redo the job on Friday and replace it with a Toyota belt. All the warning signs are there, why didn’t I listen. I also think maybe the drive belts aren't tight enough and causing the sound. IDK. Any suggestion?
