Grinding noise while driving - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2010, 11:04 PM   #1 (permalink)
View caveman017's Photo Gallery
Being a college student really has made me the DIY kind of person. Anyways, I was planning on replacing my brake pads over summer after I got home. On my way home this weekend, I start to hear a slight grinding noise near my front right. At highway speeds, its not really noticeable, but just when I was on the way home through the neighborhoods, it became pretty loud. I wasn't able to take the wheel off (the bolts are too tight, so I'll need to get a new wrench) , but through the wheels, it doesn't look like the rotor is badly scraped or anything.
Any ideas if its just the brake pads worn down?
1997 Camry LE, i-4, auto, KYB GR-2 and mounts in the front
caveman017 is offline   Reply With Quote
Old 05-09-2010, 11:46 PM   #2 (permalink)
View Novice_cardude's Photo Gallery
A couple questions to narrow things down a bit for me and the other folks here:
Does it only made the sound when you are on the brakes? If it's a constant grinding with your foot off the brakes, it's probably not low pads.
Does the noise change with the transmission in neutral/clutch depressed?
Does the sound change while turning either direction?
Also even if you can't get the wheels off, raise the front of the vehicle, put the transmission in neutral, and spin the wheels to see if you can duplicate the noise.
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
Novice_cardude is offline   Reply With Quote
Old 05-10-2010, 12:42 AM   #3 (permalink)
It doesn't matter if the brakes are on or not. I originally noticed that the car was "sticking" when my foot went off of the brake pedal ( almost like having your car in drive with the parking brake slightly on), which I assumed was the brakes.
I didn't really pay attention to the turning aspect.
It makes the noise when in neutral as well.
Old 05-10-2010, 01:16 AM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Sticking caliper?
Old 05-10-2010, 01:23 AM   #5 (permalink)
When I take the wheel off and change the pads (I assume this is minimal tool requirements?) it will unstick?
Old 05-10-2010, 01:46 AM   #6 (permalink)
View Camry LE 94's Photo Gallery
this is not much of any help but i had the same issue with my 96 I4 when I first purchased it. the one wheel would make a grinding noise... I never found out what was causing it, but it eventually went away on its own. it's probably nothing to worry about, unless there is some kind of drastic indication that there is something wrong.
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 05-10-2010, 10:26 PM   #7 (permalink)
View Rattlin_Steele's Photo Gallery
Assuming it's a stuck caliper it will likely unstick when you compress it during a pad change, but you really need to determine why it stuck in the first place because it's likely to re-occur. A sticking caliper often makes the car pull to that side and if it's stuck badly, cause a violent shaking and overheat the rotor bigtime causing it to warp.
I've had a pad crack before, which acted a bit like you describe.
Rattlin_Steele is offline   Reply With Quote
Old 05-11-2010, 08:33 PM   #8 (permalink)
Well it ended up being the caliper stuck. I took a lot (i mean a lot) of pressure and force to get the thing to retract once off.
When I got the wheel off, found out that the pads had burnt through and my rotor was trashed (especially the inside!). $45 later for a new rotor and pads and I'm back in business.
One problem though. It seems that the wheel / new rotor are burning hot when driving around, while my other wheel isn't. I'm assuming the caliper is still the culprit?
Old 05-11-2010, 08:47 PM   #9 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Yeah change that caliper asap before it eats through your new pads
carsrus is offline   Reply With Quote
Old 05-12-2010, 05:43 PM   #10 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Yeah change that caliper asap before it eats through your new pads and Rotor!
^^ + 10
make that +20 if you do them both and flush the system real good. Drums in back or disc?
73sport is offline   Reply With Quote
