Testing ABS Break - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2010, 04:23 AM   #1 (permalink)
View sanlen's Photo Gallery
Testing ABS Break
Hi All,
Could you please advice how can i test the ABS break during driving the car?
How to make sure that this ABS system are working properly by doing a drive test?
Thanks you very much for your time.
sanlen
sanlen is offline   Reply With Quote
Old 05-11-2010, 05:07 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
find empty parking lot/road get to like 20 mph slam on the brakes and you should feel the abs pulse
^ and leaving it that way!
Old 05-11-2010, 08:57 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
step on the pedal to the left?
might be easier if you do this when the roads are wet.
Old 05-11-2010, 01:03 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
+1
'07 Honda Ruckus Big Bore
Old 05-11-2010, 08:08 PM   #5 (permalink)
Thanks you very much for the tips.
Most of the morning when i start my car, the ABS light never go off untill i off the engine and start it again. this is only happened in the morning
is this the sign of ABS getting problems?
thanks
sanlen
Old 05-11-2010, 08:17 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
In normal situations, the ABS light should come on briefly to show you that the bulb is working, and then it should turn off. An ABS light that's on all the time means you have problems in the ABS system, and therefore the ABS control unit shut down the system. The entire brake system behaves as a non-ABS system.
If the bulb goes off after a long time being on, you might want to check the bulb first. Register on Autozone's free repair guide and follow the procedure of pulling the diagnostics code from the ABS system to learn what's wrong.
http://www.autozone.com/autozone/rep...nfoLanding.jsp
thanks
sanlen
