Where does this go 2mz-fe (pics inside) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2010, 12:54 PM   #1 (permalink)
96 es300 2mz-fe
Gameroom cash: $135325
View Brandoe91's Photo Gallery
Engine - 2mz-fe with 1mz-fe Intake manifold and throttle body.
Problem - cable coming from the bottom of throttle body is just hanging in the engine bay, where does it go and what is it?
thanks in advance
Brandoe91 is offline   Reply With Quote
Old 05-11-2010, 02:54 PM   #2 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
hmm . . .
Cable or Hose?
Looks like you have two things in question. The top photo "starts here" is warm water from the engine block which is circulated through the IAC valve right at the bottom of the T/B.
The next photo is the IAC air line to the intake manifold for the injectors (at or near galleys drilled and feeding air to the fuel injectors. I think!) Need a picture from just a bit farther away to see where it really goes.
You look in here yet? >> 1MZ-FE Engine (V6) (24.92MB)
Search for IAC removal.
Take a couple shots from further away too!
73sport is offline   Reply With Quote
Old 05-11-2010, 03:34 PM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
looks like the manifold coolant bypass hoses. weird how you have a 2mz in north america.
anyways, its nothing critical. i would imagine the lines run to different but similar places between the different generations of manifolds, which it why the pre bent hose seems to go to nowhere.
rusty9 is offline   Reply With Quote
Old 05-11-2010, 03:34 PM   #4 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
Here's my 2 cents. I agree with 73sport that it is from the IACV (Idle Air Control Valve) under the throttle body. But I think it's the vacuum line that goes to the intake manifold. It looks like somebody did a ghetto plug job on the hose and plugged it with a spark plug
I think the line goes here, you might want to check this and see if your engine looks like this. I'm betting that the place where the hose should go into the manifold is plugged as well with who knows what.
ajkalian is offline   Reply With Quote
Old 05-11-2010, 03:46 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
I agree with above. it looks like an Air Assist hose connecting IAC valve body with cylinder head, it's an air/vacuum line i think. that spark plug on end killed me LMAO
wondering why someone did it. maybe IAC is wrong model and there is nothing to connect to on engine head end ? or maybe there is a nice plug over there too (another spark plug? LOL, couldn't resist)
check how many hoses starts from IAC, if there is just 2 and one is blocked then it has to be coolant bypass disconnected and blocked. if 3 hoses start from IAC then it's most likely the air hose for injectors (nothing critical).
i think your intake manifold and throttle body might be a California emission 1mz-fe with air assist port & tube (federal version didn't have it) while your engine doesn't have it, so it might be reason why it was plugged (engine has no port for it).
Old 05-11-2010, 04:18 PM   #6 (permalink)
V8'sRGone
73sport's Avatar
Interesting seeing everyone's feed on this. . . Same results, but . . .
My assumption is the 2mz is smaller displacement then the 1mz so someone is trying to get more FUEL and AIR in to that 2Mz using those parts!
Just a WAG!
Old 05-11-2010, 04:19 PM   #7 (permalink)
V8'sRGone
73sport's Avatar
Originally Posted by ajkalian View Post
What year what body is this in?
Old 05-11-2010, 05:26 PM   #8 (permalink)
96 es300 2mz-fe
thanks for the info.Will take another pic soon.
Originally Posted by 73sport View Post
hmm . . .
Cable or Hose?
Old 05-11-2010, 05:28 PM   #9 (permalink)
96 es300 2mz-fe
It's from japan so possibly. thanks
Old 05-11-2010, 05:35 PM   #10 (permalink)
96 es300 2mz-fe
It is a smaller displacement (2495) . not sure why my mechanic plugged it.
Just a WAG!
Old 05-11-2010, 05:39 PM   #11 (permalink)
96 es300 2mz-fe
i will check but remember it's not a 1mz-fe .
Old 05-11-2010, 05:54 PM   #12 (permalink)
96 es300 2mz-fe
got it from japan (2mz-fe)
Old 05-11-2010, 06:18 PM   #13 (permalink)
You mean mine, or the guy that started the thread?
It's a 2000 Camry LE, 1MZ-FE, 6cyl. Yee, haw, made in Kentucky.
Body (??) 4-door. You mean the MCV20L-CEPNKA ?
Old 05-11-2010, 11:32 PM   #14 (permalink)
V8'sRGone
73sport's Avatar
Yours, thanks!
Just observing the subtle differences over the years. . .
Old 05-11-2010, 11:34 PM   #15 (permalink)
V8'sRGone
73sport's Avatar
Rusty has it correct. . .
