Oil pan gasket (1MZ) - to be or not to be? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2010, 01:26 PM   #1 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
Subj! Do you think it is a good idea to use aftermarket oil pan gasket or just use FGIP-like stuff? Cons and pros? I think, oil pan gasket is easier to use than that silicone stuff.... What is your experience?
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 05-11-2010, 02:01 PM   #2 (permalink)
Quattrovalvole's Avatar
View Quattrovalvole's Photo Gallery
Honestly, about 6 months a go I ordered a FelPro from Autozone and so far no problems .....
_______________________________________________
1997 Camry LE V6
16' Enkei's
Pura vida from Costa Rica
Quattrovalvole is offline   Reply With Quote
The Following User Says Thank You to Quattrovalvole For This Useful Post:
Nervous (05-11-2010)
Old 05-11-2010, 02:35 PM   #3 (permalink)
View Rattlin_Steele's Photo Gallery
I went with OEM FIPG based primarily on the advice in this post:
Assembly, Start-up and break in of New/rebuilt engines. . .
plus I was already ordering a bunch of OEM gaskets, seals, etc from an OEM parts supplier, so I just threw in a tube of FIPG for ~ $10
So far no leaks.
Rattlin_Steele is offline   Reply With Quote
The Following User Says Thank You to Rattlin_Steele For This Useful Post:
Old 05-11-2010, 02:38 PM   #4 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
FIPG all the way. . .
While your waiting for parts, I'd drain the oil and yank the battery <<Fail safe, engine no start<<.
After its done dripping for week, yank the pan. Get every trace of of the old FIPG off both parts. Clean it with acetone, and reapply some name brand FIPG.
Its the best material for the job if applied correctly.
Also, you might want to wipe up in the sump area to reduce the amount of fresh oil running down and making contact with the new FIPG so it can cure without having oil present.
73sport is offline   Reply With Quote
The Following User Says Thank You to 73sport For This Useful Post:
