O/D light blinking-transmission code 61 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2010, 01:48 AM   #1 (permalink)
View Gnicetry's Photo Gallery
3rd Generation O/D light blinking-transmission code 61
Hello-
I jumped the fuse port? in the engine compartment and came up with code 61. My tranny works fine and shifts well. After the car is started it will only start to blink when I am near 4th gear (o/d). I was told speed sensor #2. Any help??
Gnicetry is offline   Reply With Quote
Old 05-14-2010, 04:55 PM   #2 (permalink)
I know that I am new but does anyone have any info on this?
Old 05-15-2010, 12:51 AM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
What I did was look up the part (not sure if this is the correct one) on rockauto.com:
http://www.rockauto.com/catalog/moreinfo.php?pk=446251
Look like an expensive one too. This thing basically sends pulses to the ECU. So I guess when you get into OD the ECU is no longer receiving the pulses or some other fault. But this also means it works in 1-3???
I think a multimeter test may be the way to go first.
