Need a Tune up Parts list '93 camary/also dies for no reason
Hi I need to know a parts list for a tune up on a 1993 camary with almost 200,000 miles. Also if the car is off and you play the radio too long, somtimes not always it will start and run for about 30sec. then die. One has to put on the brake, start it, and rev it above 2500 rpm and then after about 10 min it will run fine. Also has a knocking sound when turning corners.
I have put new cv axles on it , a new radiator, oil/filter change every 3,000 miles, New fuel filter, New struts, New timing belt. I just want to solve theese last few issues. I also have some oil leaks.
Any help will be greatly appreicated. Thanks!!
but I'd say start with air filter. spark plugs, inspect with likely buying distributor cap, rotor, ignition wire. Look at some of the rubber parts. hoses, belts.
The Following User Says Thank You to Judge2 For This Useful Post:
But to answer your questions, we would need to know if you have an I4 or V6, and approx where the oil is leaking. Is it leaking near the timing belt area, near the distributor, etc?
I agree with judge2: air filter, spark plugs, rubber components, spark plug wires, oxygen sensors, pcv, see if you have any vacuum leaks...
95 Camry LE I4 195k
The Following User Says Thank You to bdy0003 For This Useful Post:
Definitely clean the idle air control valve. I would also change the PCV valve. You might want to replace fluid like the transmission, differential, and coolant.
The Following User Says Thank You to schumionbike For This Useful Post:
Valve covers, I'm assuming you have a V6? So your valve cover gaskets need to be replaced and if there are indeed leaks on the pan, maybe the pan gasket? Anyone want to chime in?
I don't have a V6, but on my I4 the distributor o-ring was leaking, so maybe something along those line too?
95 Camry LE I4 195k
Thanks For All Your Help I Got My 4cyl 1993 197000 Miles 2200 All Tuned Up And Most Of The Oil Leaks Fixed. Thanks To All Of You. I Don't Know How To Take This Off The Bulliton Board But I Will Be Back When Somthing Breaks And I Need To Fix It. Thanks Again For All The Help It Was Appreciated. Bsrmoo
