How can I make my car recognize a new ignition key? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2010, 08:50 PM   #1 (permalink)
View 500KCamry's Photo Gallery
4th Generation How can I make my car recognize a new ignition key?
Have a 2001 XLE with keyless entry.
Ignition key tumbler died. I installed a new one and the car will crank but not start. Apparently the car is programmed to recognize the old key, not the new one. I made a temp fix by removing the key sensor ring from around the tumbler, and let it hang with my old key taped to it. The car now starts.
Does anyone have a method for making the car recognize a new ignition key? Or am I stuck going back to the dealer 600 miles to the south .
Searched the forum, couldn't turn up an answer. Thanks.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 05-14-2010, 12:09 AM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
http://www.solaraguy.com/viewtopic.p...ht=key+program
The process is a ways down in the thread. Solara/Camry is the same car.
5 Lug Corolla WHAT?
The Following User Says Thank You to ASG14 For This Useful Post:
500KCamry (05-14-2010)
Old 05-15-2010, 05:09 PM   #3 (permalink)
Hi, thanks again. For the Camry the process as written is correct and to confirm step 1, you have to depress and release both pedals before starting step 2.
Also, they send two keys with the new lock, and although the keys are cut the same, the codes for the keys are different, so you must go through the process for both keys, to add both key codes to the car.
Disappointed that Toyota won't volunteer the procedure especially when the nearest dealer is 8 hours away and they'll already supplied and been paid for the parts. Also $100.00 programming charge for less than two minutes of work pushing pedals seems excessive.
01 XLE V6 310K km
Old 05-15-2010, 06:36 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
yeah, only one of keys is master, the other is a valet key i think. your car has the immobilizer in it that's why programming of keys was necessary, mine doesn't have this feature (have alarm though), so i got my blank key of ebay for $11 and dealer cut it for free (no programming).
