1993 LE Camary 4cyl. I Have Questions Please answer asap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2010, 06:37 PM   #1 (permalink)
View BSRmoo's Photo Gallery
For the oil pan on a 1993 4 cyl 2200 automatic LE camary, do you need to do anything special to get it out. I can not get to the 4 last bolts?? Also the spark plugs What is the Gap supposed to be?? Thanks RC
BSRmoo is offline   Reply With Quote
Old 05-15-2010, 06:58 PM   #2 (permalink)
2win2rbo's Avatar
Gameroom cash: $156522
View 2win2rbo's Photo Gallery
I believe it's supposed to come off after all the bolts have been removed. The bolts are at least a few mm away from the exhaust or the sub-frame.The spark plug gap is supposed to be 1.09 mm based on the service manual.
1993 Toyota Cresta Tourer S JZX90
1988 Toyota Mark II GX71
1999 Subaru Outback 5-speed
2000 Toyota Mark II IR-V
2003 Subaru Legacy BP5 2.0R
2win2rbo is offline   Reply With Quote
The Following User Says Thank You to 2win2rbo For This Useful Post:
BSRmoo (05-17-2010)
Old 05-15-2010, 07:08 PM   #3 (permalink)
View BlueGoat's Photo Gallery
Remove the engine undercovers using a ratchet, extension and socket. Then Detach the front exhaust pipe from under the engine using a breaker bar and socket Remove the engine mounting center. Take off the end stiffener plate from the rear side of the engine oil pan. Loosen and remove the oil pan bolts. If need be cut the oil pan gasket sealer from the sides. Sorry if iv missed anything
BlueGoat is offline   Reply With Quote
The Following User Says Thank You to BlueGoat For This Useful Post:
BSRmoo (05-17-2010)
Old 05-17-2010, 09:25 AM   #4 (permalink)
Thanks I Got It Out! What A Chore. Thanks For The Help!!!!! I Am Done, I Dont Know How To Delete This Thread. Thanks Again. Bsrmoo
