So I've decided to clean my weapon r secret intake and I finally decided to try and figure out what that extra gray hose connects to. Me and some friends spent about an hour trying to figure out what it connected to but failed. A few days ago I found a pic of a 5sfe with the same intake with the hose connected...i don't remember where i found the post
Does anyone know what it connects to?? I hope I'm not fucking up my engine :/
IIRC, that should go to your vavle cover breather hose.
I just looked at the valve cover hose, which is also connected to some part of the manifold. So do i leave the opening on the manifold open when i connect the hose to the valve?
one side connects to the intake hose (weapon r intake pipe) and the other goes to the valve cover, like big bird said. there are 2 hoses that do this. one connects to where you are missing it and the other is a real tiny 1 that goes from the valve cover to the throttle. there should be nothing going to the manifold from the valve cover
plug the hole in the manifold, that would be called a vacuum leak
Isn't there a small hose connected to stock intake tube near the throttle body? The connection for that hose on the stock intake tube faces the firewall. You connect that hose to what you're pointing to.
That's what I did to with my CAI...
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
could some one tell me how to set a cold air intake up on a 96 camry with the california emisions it a 4cyl
I'm from Cali. Check my pics^. That intake is in a Cali emission car.
Thanks, and where did you get a cold air intake for the 2.2l??? is it custom because I rather had a cai instead but settled for the weapon r secret because of its cold air ram air kit
It's custom. I got it from another TN member a long time ago. It sounds great, but I have lost a bit of torque on the bottom end. Works really good at highway speed though. Unfortunately, I have to reinstall the stock system for smog checks.
