94 Camry. How to replace rear driver strut? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2010, 07:06 PM   #1 (permalink)
Gameroom cash: $120300
View johnjan's Photo Gallery
I have a Camry LE 94. Can someone please guide as to how to replace the rear driver side strut?
Any cheap sources for new struts? I am tired of using salvage yard struts. They fail within one year.
johnjan is offline   Reply With Quote
Old 05-17-2010, 07:26 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
rockauto.com and ebay
drop the back seats remove the high mount stop then the back deck you see where the top bolts, jack the car up remove the wheel, 2 bolts holding the strut from the hub, then the 3 top bolts, reverse
^ and leaving it that way!
Old 05-17-2010, 07:42 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
that would be for swapping the whole strut assembly, right?
The Following User Says Thank You to fenixus For This Useful Post:
johnjan (05-19-2010)
Old 05-17-2010, 07:58 PM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
yup, search on here you the strut rebuilding if you go that route, buying the quick strut is most of the time the best unless you want a sportier feel where you need to assemble your self
Old 05-17-2010, 08:43 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
For the rears the Monroe Quick Struts are available. They're on rockauto.com for about $160 plus shipping. TN members get 5% off. And they carry a lifetime warranty (purchased after 1/1/2010). Which means it may be worth it to buy at a local parts store honoring that. I like Autozone's no non-sense LLT warranty return policy.
A shop shouldn't charge more than $50-60 per corner to swap out struts. See if you can negotiate a deal for all corners. You may need an alignment after that however. Another $60 or so.
So how much are you paying for salvage yard assemblies?
Old 05-19-2010, 03:27 PM   #6 (permalink)
Yes, the whole strut assembly.
Thanks for the suggestions.
Old 05-19-2010, 11:41 PM   #7 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349653
View BMR's Photo Gallery
johnjan, here's a link to a DIY thread I did a while back on rear strut replacement on my '92 Cam...
Click me
BMR is online now   Reply With Quote
