sway or strut? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2010, 05:13 AM   #1 (permalink)
Unofficial TN Member
Darchrow Enigma's Avatar
Gameroom cash: $154200
View Darchrow Enigma's Photo Gallery
4th Generation sway or strut?
i take my car into the mountains once in awhile and the roads are narrow and curvy, and i can't go at the speeds that the porsche tailgating me can.
to get better handling when taking curves, do i need a strut bar or a sway bar for stiffer suspension? (i'm hoping not to have to replace the shocks/suspension lol)
Darchrow Enigma is offline   Reply With Quote
Old 05-19-2010, 06:17 AM   #2 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
In order to keep up with a Porsche you will need a rear sway bar, springs + struts + chamber kit, and wider wheels with stickier tires. it wouldn't hurt to loose some weight as well.
While I believe that all of the above mods are worth it, It would be much cheaper to just pull over and let the Porsche pass.
SexieWASD is offline   Reply With Quote
Old 05-19-2010, 06:34 AM   #3 (permalink)
i don't mind letting faster cars pass, neither am i trying to keep up with a porsche in a camry.
i just want to be able to take the curves better than what the stock vehicle is able to handle right now...you know, even when i'm the only car on the road.
Old 05-19-2010, 06:48 AM   #4 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
Rear sway bar will make a much larger difference than a strut bar.
But strut bars can be found for low prices on ebay and they're good enough to help a bit with stiffening the front.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is offline   Reply With Quote
The Following User Says Thank You to DxElite For This Useful Post:
Darchrow Enigma (05-21-2010)
Old 05-19-2010, 09:42 AM   #5 (permalink)
Gameroom cash: $323580
View Cartang's Photo Gallery
4th Generation
Sway bar thicker , strut bar , aftermarket spring , perf struts ,agree with SexieWasd
Camry 99,SC 6psi,5sp,CPE intake,OBX headers, Jim's fuel system,Walbro pump, NST pulley,Greddy exhaust,Whiteline sways bars ,TRD strut bar,TRD shifter,Exedy clutch,Fidanza flywheel.
Camry2007 ,V6,SE,TRDcat back system, Fujita CAI,TRD springs ,UR(R) sway bar 23 mm,UR(F) 4 points,Lexus GS 430 rims.
Cartang is offline   Reply With Quote
The Following User Says Thank You to Cartang For This Useful Post:
Old 05-19-2010, 02:24 PM   #6 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
If someone tailgates you again, take your foot of the gas, and slow down. They will either back off, or go around you. Don't let a tailgater bully you into doing something stupid.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 05-19-2010, 02:46 PM   #7 (permalink)
View 3point0coupe's Photo Gallery
make it easy for u to pick
front strut brace - help reducing body roll
Sway bar- controls how far over the body rolls in a corner.
3point0coupe is offline   Reply With Quote
The Following User Says Thank You to 3point0coupe For This Useful Post:
Old 05-19-2010, 03:59 PM   #8 (permalink)
93 Camry LE 5S-FE
4Cyl'erThriller's Avatar
Gameroom cash: $428696
iTrader Score: 15 reviews
View 4Cyl'erThriller's Photo Gallery
Rear sway bar!!!!
Struts/Springs
Strut bar.
4Cyl'erThriller is offline   Reply With Quote
The Following User Says Thank You to 4Cyl'erThriller For This Useful Post:
Old 05-19-2010, 04:09 PM   #9 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
like others have said...start with teh sway bar, then stiffer springs and shocks. if your not looking for a lowered stance then something like eibachs are perfect because they dont lower the car much.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
The Following User Says Thank You to bigbird For This Useful Post:
Old 05-19-2010, 08:59 PM   #10 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
There is a way to get the same performance as a Porsche in a Camry. Except it will cost as much as a Porsche. It's call a trade-in.
Other than that, try White Line sway bars. And search TN member threads using this product.
http://www.whiteline.com.au/
You can also get a strut bar if there is a Solara equivalent for your model year. But sway bars first. I think your struts are probably shot.
Old 05-19-2010, 09:02 PM   #11 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
The rear sway bar is also called an anti-roll bar, anti-sway bar, etc. It's purpose is to reduce body roll in the way that it attaches the rear suspension and works by a twisting motion. With aftermarket springs/struts and adding the sway bar, it was a night/day difference. The strut bar, not so much, but it did stiffen up the front of the chassis a bit and I felt that it helped to control some of the oversteer induced by the sway bar. That's just my experience though. If you really want increased handling, I'd get a set of coilovers before springs, struts, and RSB. Like other said, tires are also important.
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is offline   Reply With Quote
Old 05-20-2010, 12:51 AM   #12 (permalink)
awesome, thanks for the informative posts
(i'll likely upgrade more parts, but not all at once...kinda broke here, haha)
i don't think my struts are blown, my car doesn't bounce like a motorboat does on the sea.
more questions though...
1. where are some reputable places i can purchase these parts? (http://www.whiteline.com.au)??
2. i was planning on taking the parts to a local mechanic to have them installed for me...is that wise, or are there some sort of specialty shops that i should take it to instead
3. i don't want to lower my car...is it possible to replace the springs without lowering the car? (eibach's, as mentioned above?)
thanks! appreciate it very much
Old 05-20-2010, 02:11 AM   #13 (permalink)
pardon the double post, everyone, but should i buy these?
Brand New Eibach Springs 8249.140 Camry Solara
is this a good deal?
Old 05-20-2010, 06:34 AM   #14 (permalink)
View VonDeLinde's Photo Gallery
but a porsche
VonDeLinde is offline   Reply With Quote
Old 05-20-2010, 10:13 AM   #15 (permalink)
DxElite's Avatar
1. I bought my Whiteline RSB from NeverEnoughAuto.com. Use their Maximum Advertised Pricing (MAP) offer to get a lower price and compare it to other sites.
2. Regular mechs are fine, as long as their reputable and won't damage anything and put the cost to you. The sway bar mount can sometimes be stuck and hard to put back on and there have been stories of it getting damaged.
There are DIY threads, if you're okay with doing basic auto work, just socket set and jack stands, you could probably do it yourself.
It's an okay deal. With shipping at ~$40 that will make it ~$225. That's cheaper than most places retail without shipping costs.
Couldn't hurt to shoot him an offer to try to get the total cost down a bit.
