Which belt is loose? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2010, 01:15 PM   #1 (permalink)
View .Camryman97.'s Photo Gallery
A few months ago i got my timing belt replaced along with the water pump. Well a few weeks ago when i would first start my car after being off for a while and then turn on the a/c some belt would start squeeling and would stop as soon as i turned off the a/c so i know it's a belt that has to do with the a/c. anyone know which belt it is?
thanks!!
97 Camry: 17" Enkei rims, lowered with Ground Control and tokico,
Alpine head, mids, and highs, rockford 4-channel, 12" P3 rockford,
MTX monoblock, TRD RSB, Clear Corners, 6K Mod Express HID kit
.Camryman97. is offline   Reply With Quote
Old 05-19-2010, 02:18 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
most likely it's the a/c & alternator accessory belt (top one on 5s-fe).
get your original part number from here (give it your VIN):
http://www.toyodiy.com/parts/
then get a new OEM belt from toyota online dealer (~$8.76 shipped) from:
www.toyotapartsoutlet.com
if your car is '97 Camry 4cylinder then you need this belt: 90080-91122-83
they are good quality, they won't start getting loose and longer and longer (and snap at some point) after as little as 3-4 months which is common to cheap aftermarket belts. OEM belts are either Mitsuboshi, Bando or something else i forgot.
I got Bando last time ordered from them (it's so cheap than it wouldn't make sense to get good brand belt from autozone for $22!!).
Old 05-19-2010, 02:47 PM   #3 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
Since the timing belt was replaced recently and if it were the alternator belt, you might want to inspect it for loose, stretchiness, not put on properly...etc. In order to replace your timing belt, the alternator and the belt are removed.
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 05-19-2010, 02:56 PM   #4 (permalink)
View 3point0coupe's Photo Gallery
it the alternator belt .. to test the belt try used wd40 and spray the belt and see if the squealing stop..
3point0coupe is offline   Reply With Quote
Old 05-19-2010, 04:39 PM   #5 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
I hope you're joking, you never ever spray any petroleum based product on a belt.
71Corolla is online now   Reply With Quote
The Following User Says Thank You to 71Corolla For This Useful Post:
SexieWASD (05-19-2010)
Old 05-19-2010, 05:21 PM   #6 (permalink)
Gameroom cash: $303255
When repalcing the timing belt most shops would also try to sell you on replacing the 2 accessory belts at the same time. Were these 2 belts replaced when the timing belt was changed? If so, one or both of the belts has stretched out a bit and is now loose. This is very common. They may simply need to be retightened. If you are not sure if they were replaced at that time, I would check your receipt.
Mike
Old 05-19-2010, 05:24 PM   #7 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
+1
if you want to check if it is the belt, do it the old school way. Rub a bar of hand soap on the belt. I've done this on my 89 'yota pickup, my Grand dad's '66 Malibu, and my '65 Mustang. Works every time, but it's only works for a short time, maybe a day or two. With this method, you'll at least be able to confirm belt slip.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 05-19-2010, 07:37 PM   #8 (permalink)
well im almost positive ive had the alternator belt replaced when i got my PS belt replaced(they failed me on inspection because of the PS)
but not 100% sure. i got the timing done at my uncles shop so im sure he'll can check on it no problem
Old 05-19-2010, 08:10 PM   #9 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Maybe the tensioner is loose. Mine was and the belt kept slipping and squealing.
Chris Crash is online now   Reply With Quote
