Search around, I think other helpful TN members posted a parts list for 5SFE. Since you're starting with a recommended mechanic, I'd use all Toyota parts. If something goes wrong you can just blame the mechanic.
Here is an example of parts I'd use for the 5SFE timing service off rockauto.com. Again, I highly recommend that you check online dealer sites like 1sttoyotaparts.com, etc. etc. The final cost is close and most people just feel better using OEM.
Make sure the mechanic uses Toyota Red coolant and distilled water, not tap water like many "prefer" to use. So bring a gallon of steam distilled water (with no minerals added for taste
) -- 70-cents or something.
5SFE parts prices from rockauto:
GATES TCK199 (shrink-wrapped tray of one timing belt with two pulleys and instruction)
$52.79
GATES Part # K030295 PS belt $4.92
GATES Part # K050435 Alt/AC $12.32
FEL-PRO TCS45641 Cam seal $3.70
FEL-PRO TCS45920 Crank seal $5.62
BCA Part # 221820 Oil pump seal $3.45
AISIN WPTK010 (Toyota #16100-09040, 16100-79185-83) water pump $43.79
FEL-PRO VS50304R valve cover gasket set $13.94
(used to include spark plug tube seals, but no longer?)
STANT OE-style thermostat with jiggle valve Part # 48278 $10.96
FEL-PRO Thermostat Gasket Part # 35292 $1.54
Radiator Cap STANT Part # 10241 $5.48
(no need to change the rad hoses if Toyota recently did them)
Upper radiator hose GATES Part # 21963 $10.47
Lower radiator hose GATES Part # 22271 $8.60
NGK Part # 3764 IX-Series Iridium #3540, BKR6EIX11, BKR6EVX11 $6.40 x4
(NGK catalog shows this as approved for the Gen 4 waste-spark application, but not the Laser Iridium plug with a platinum ground pad).
Total about $184.11 + shipping. (not incl rad hoses)
They had an older 5%-off code that just expired for TN members. But google around you'll find other current codes.
Also, the belts should be installed using a Krikit-II tension gauge (~$20 on Amazon) or a more professional dial tension gauge that most shops don't have and dealers probably don't use. Parts stores just gave me the blank stare when I ask for it. Most mechanics use the "deflection" method, but I personally don't care for that.
Given that you have a split down the middle of the ALT/AC belt, I would carefully check the condition of the pulleys too.
Originally Posted by Darchrow Enigma
so..i've decided to purchases parts myself and supply a local mechanic that was highly praised by a friend, and people on yelp agree. i called him up and he said he'll charge me only labor if i supply the parts myself.
are these all i need to bring to him?
timing belt
water pump
crankshaft seal
camshaft seal
oil pump seal
thermostat
tension pulley
idler pulley
and...since my AC belt is cracked...that too.
anything else i'll need?
thanks guys for all your help!
