Rims + Tires? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2010, 01:39 AM   #1 (permalink)
AbsolutAdikt7's Avatar
View AbsolutAdikt7's Photo Gallery
Wink Rims + Tires?
Whats good guys?
I can't stand the look of these hub caps anymore, need some rims.
What size rims fit on the gen 3.5 Camry? (without rubbing)
What sizes do you guys have?
I probably wont be lowering the car so what do you think will look fresh and appropriate?
1995 Green LE Camry
155,000 miles
4 Cyl 2.2
AbsolutAdikt7 is offline   Reply With Quote
Old 05-21-2010, 08:03 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
theres a stickied thread in the general camry discussion section called "lets talk offsets". lots of wheels ther with specs listed. other then that you gotta look around man, its your car, find a look you like.
personally i would get the suspension before the wheels, they will end up costing about the same and the car looks a little weird with nice wheels but no drop. just IMO.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 05-21-2010, 08:10 AM   #3 (permalink)
92 Camry 5S-FE
LittleWhiteBubble's Avatar
Gameroom cash: $115750
View LittleWhiteBubble's Photo Gallery
If you want to keep it stock height the biggest rim size I would go is 17. Any bigger than that while still trying to keep the same overall tire diameter as stock is going to give you a really thin tire. So they're going to be a lot more expensive and a lot harsher ride. I put 17's on mine with 215/45 tires and I like it a lot. There is a fender gap, but it's the same gap as a stock wheel on this car so I can live with it. The roads in town aren't very forgiving so dropping it isn't an option for me.
LittleWhiteBubble is offline   Reply With Quote
Old 05-21-2010, 09:47 AM   #4 (permalink)
The roads are horrible here aswell which is why I also don't want to lower. Could you post pictures of your wheels so I can see them on a stock suspention?
1995 Green LE Camry
155,000 miles
4 Cyl 2.2
Old 05-21-2010, 09:57 AM   #5 (permalink)
92 Camry 5S-FE
Sure thing, this is with my stock suspension with new struts..
I don't have a very good straight-on side shot, I'll go snap one now for you.
Old 05-21-2010, 10:01 AM   #6 (permalink)
92 Camry 5S-FE
I just took this a second ago.
It's a little hard to see the tires in this one though the way the sun was facing so the gap looks weird. But hopefully you get the idea.
Old 05-21-2010, 01:36 PM   #7 (permalink)
Looks very nice. I will be looking into getting some rims around that size. Whats the bolt pattern or whatever that fits the 95 Camry?
1995 Green LE Camry
155,000 miles
4 Cyl 2.2
Old 05-21-2010, 01:40 PM   #8 (permalink)
92 Camry 5S-FE
92 and up were all 5x114.3 which is a pretty common lug spacing, and make sure its a high offset for a front wheel drive car. If you get universal 5 lug like mine are, all the universal ones should have 5x114.3 on them.
